Last missing to make whole of it to make sense to me are _IORD/_IOWR signals. How would I replicate this?terriblefire wrote: Wed Oct 07, 2020 8:32 pm The solution to this is to assign one of the INTSIG wires to A5 in the CPLD.
assign INTSIG[x] = A[5]; etc.
This is why i have spare lines for.![]()
to make sure your IP is added into the firewall whitelist, thanks
TF CD32 Riser Revision 2 Design Complete
- arkadiusz.makarenko
- Moderator Team
Re: TF CD32 Riser Revision 2 Design Complete
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
IORD = Bus request + RW higharkadiusz.makarenko wrote: Wed Oct 07, 2020 9:06 pm Last missing to make whole of it to make sense to me are _IORD/_IOWR signals. How would I replicate this?
IORW = Bus Request + RW low
So you dont need to emulate these... this can be abstracted away.
- Moderator Team
terriblefire wrote: Wed Oct 07, 2020 9:25 pmIORD = Bus request + RW higharkadiusz.makarenko wrote: Wed Oct 07, 2020 9:06 pm Last missing to make whole of it to make sense to me are _IORD/_IOWR signals. How would I replicate this?
Can I just read only value of /RW then? I will be decoded address + RW + bits of Address line, so I would have all states required to emulate RTC?
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Yeah i think thats the case. I cant remember if there was also a BUSREQ pin?arkadiusz.makarenko wrote: Wed Oct 07, 2020 10:22 pmterriblefire wrote: Wed Oct 07, 2020 9:25 pm
- Moderator Team
Those are available on edge connection, but a lot of ?? on descriptions.terriblefire wrote: Wed Oct 07, 2020 10:26 pmYeah i think thats the case. I cant remember if there was also a BUSREQ pin?arkadiusz.makarenko wrote: Wed Oct 07, 2020 10:22 pm
111 /CPU_BR CPU bus request??
112 /EXP_BG Expansion bus granted??
113 /CPU_BG CPU bus granted??
114 /EXP_BR Expansion bus request??
I will grab and test it on A1200 on clockport first if I manage to emulate MSM6242 then I will go back and test it on Riser (less moving parts)
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
No those are the arb signals...
The interrupt should be enough.
- Admin sponsor
Im happy to test this out on my CD32 when you're ready. I still have this riser and a CD32 here.
- Moderator Team
As soon as I will have something to show...terriblefire wrote: Thu Oct 08, 2020 7:46 pm Im happy to test this out on my CD32 when you're ready. I still have this riser and a CD32 here.
~ Stanislaw Lem
~ Stanislaw Lem
- Moderator Team
My first verilog that actually passed syntax check and I managed to program cpld
module address_decoder(
input [23:16] A,
input A3,
input A5,
output INTSIG2,
output INTSIG3,
output INTSIG5
assign INTSIG3 = A3;
assign INTSIG5 = A5;
assign INTSIG2 = A[23:16]==8'b1101_1100; //RTC registers at $DC0000 - $DCFFFF
endmodule
NET "A3" LOC = "P32" ;
NET "A5" LOC = "P34" ;
NET "A<16>" LOC = "P47" ;
NET "A<17>" LOC = "P48" ;
NET "A<18>" LOC = "P57" ;
NET "A<19>" LOC = "P56" ;
NET "A<20>" LOC = "P51" ;
NET "A<21>" LOC = "P52" ;
NET "A<22>" LOC = "P50" ;
NET "A<23>" LOC = "P49" ;
NET "INTSIG2" LOC = "P23" ;
NET "INTSIG3" LOC = "P24" ;
NET "INTSIG5" LOC = "P12" ;
~ Stanislaw Lem
~ Stanislaw Lem
- Moderator Team
I managed to detect RTC_SEL interrupt when looking for RTC clock in Amiga Tool Kit, so at least I know that this bit works.
I can read SOME addresses as well.
So it is time to try to put something on the bus.
~ Stanislaw Lem
~ Stanislaw Lem
