TF CD32 Riser Revision 2 Design Complete
TF CD32 Riser
arkadiusz.makarenko
Re: TF CD32 Riser Revision 2 Design Complete
Post by arkadiusz.makarenko »
terriblefire wrote: Mon Apr 06, 2020 8:37 pm I'm really hoping something like this will work on one usb port and a usb mouse keyboard combo on the other.
https://www.ebay.co.uk/p/7031293974?iid=143292049862
Dual controllers on one dongle... This might be a challenge to have support universally. At this point only one should work. But adding support for this particular device shouldn't be too difficult.
~ Stanislaw Lem
arkadiusz.makarenko
Higgy wrote: Mon Apr 06, 2020 9:00 pm Would you be thinking of say mapping PS3 controls to replicate CD32 pad? I have a PS2 controller adapter to Dtype for my CD32 as it came with no pad (or psu!).
At this point library is capable of supporting only standard PC HID gamecontrollers. It depends how hid descriptors on dongles for PS2/PS3 devices are constructed, but it is unlikely that they would work with current library. I am planning to expand support, but it may take a while.
~ Stanislaw Lem
riser_revision2.txt
(9.4 KiB) Downloaded 216 times
I'm having issues programming the F722 ...
specifically I can't erase it when i try to run something :(
Memory Programming ... Opening and parsing file: ST-LINK_GDB_server_a16228.srec
File : ST-LINK_GDB_server_a16228.srec Size : 13052 Bytes Address : 0x08000000
Erasing memory corresponding to segment 0: Erasing internal memory sector 0
Error: failed to erase memory Error: failed to erase memory
EDIT: Solved. The ARM was installed with flash read/write/erase memory protection. I guess it wasnt a new chip!
Used ST-Link Utility and set LEVEL 0 in the Options.
arkadiusz.makarenko
terriblefire wrote: Tue Apr 07, 2020 4:41 pm I'm having issues programming the F722 ...
I had some similar issues with new chip from the same family f730. Erasing with utility usually solved all issues.
Weird enough that occasionally I had to do it, because stm32cubeide just couldn't program it.
Another observation is that those seems to be more fragile than f10x series or xillinx cplds.
~ Stanislaw Lem
OK cool. I'll try and get amiga.c setup on this chip and i'll post you a board.
OK my new issue is that i start the debugger it starts debugging but dies in the sysconfig bit. :/
I agree the STM32F7's seem a lot more fussy than the 105s
arkadiusz.makarenko
terriblefire wrote: Wed Apr 08, 2020 11:18 am OK my new issue is that i start the debugger it starts debugging but dies in the sysconfig bit. :/
Have you configured SYS debugging?
~ Stanislaw Lem
arkadiusz.makarenko wrote: Wed Apr 08, 2020 5:49 pm
Is that a MCU option? I have soldered up a second board without the MCA connector and the ARM starts... Not powered by the CD32.
arkadiusz.makarenko
terriblefire wrote: Wed Apr 08, 2020 6:54 pm
Power issue or damaged mpu?
~ Stanislaw Lem
Return to “TF CD32 Riser”
