TF CD32 Riser Revision 2 Design Complete
TF CD32 Riser
Re: TF CD32 Riser Revision 2 Design Complete
arkadiusz.makarenko wrote: Wed Jun 10, 2020 7:58 pm @terriblefire
I have some issues.
Firmware with 32 cycle release I do get interrupt, but each time I try to even reprogram GPIO for output PushPull or even set 0 as open drain, CD32 crashes.
For any other firmware I even don't register interrupt.
INTSIG1 and INTSIG2 should allways be 1...?
EDIT2:
I pushed changes.
INTSIG1/2 should be inputs.
INTSIG1 = 0 = JOYDAT0
INTSIG2 = 0 = JOYDAT1
Safest thing is to set everything to input except INTSIG8
arkadiusz.makarenko
Post by arkadiusz.makarenko »
terriblefire wrote: Wed Jun 10, 2020 8:25 pm
I have some issues.
EDIT2:
I pushed changes.
When I set up interrupt on falling edge of intsig1 then when I read busint as 1 (not the other way round), but when I try to reconfigure D0-D7 to allow write to pin any data on bus I got CD32 crash. I assume Amiga is already doing something else (?) Maybe 32 cycles have passed already and I mess up data bus?
~ Stanislaw Lem
Ok let me read over the code.
I'd thought EXTI was setup for BUS_INT (pin 61) possibly it can both.
I am expecting 32 cycles to take 2000uS but you can go back to the older one that locks up. Just flash the cpld after boot.
OK i've not had a minute to look at this. I'm tempted to fall back to the SPI transfer mechanism we had in revision 1.
arkadiusz.makarenko
terriblefire wrote: Sun Jun 21, 2020 10:29 am OK i've not had a minute to look at this. I'm tempted to fall back to the SPI transfer mechanism we had in revision 1.
Would it be easier?
~ Stanislaw Lem
arkadiusz.makarenko wrote: Sun Jun 21, 2020 11:23 am
Would it be easier?
Much. But being able to put the ARM on the bus is going to be needed for the CD32 buttons.
arkadiusz.makarenko
@terriblefire
Do you think you could share current Rev 2 eagle by any chance.
I was thinking of scaling down this to Minimum Usable Product? So replacing obsolete PS2 to USB HID keyboard and video out?
Do you think there would be value in this?
~ Stanislaw Lem
arkadiusz.makarenko wrote: Thu Jul 16, 2020 8:44 pm @terriblefire
Give me a day or two and i'll see if its on my laptop
kulamario
Post by kulamario »
Welcome
Lads any chance for get gerber files ?
Its all on github but it doesnt work yet.
Return to “TF CD32 Riser”
