Check if your IP is banned
viewtopic.php?t=7286
TF CD32 Riser Revision 2 Design Complete
- Admin sponsor
Re: TF CD32 Riser Revision 2 Design Complete
Yes except the address is just one pin between the CPLD and ARM. One pin for Mouse, One pin for Joypad1 and another for joypad2. Thats it unless we want to try and inplement flashfloppy.
The reason we dont always make it decode these is incase someone wants to put a real mouse or joypad in the machine.
EDIT: Keyboard will work without the CPLD at all. Keyboard is wired direct to the arm on rev1.
- Admin sponsor
I pulled the latest code from the repo and i get a hardfault every time? Needs the cap?
- arkadiusz.makarenko
- Moderator Team
@terriblefire
Hi Yes add the cap (I added 10uF as I didn't have 4.7uF), or change this in main
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
to this
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
or comment it out altogether.
I was playing with power settings and forgot to change it back.
to this
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Added the cap and now i have working USB keyboard
right so you need a way to override individual memory locations?
- Moderator Team
Only those required for mouse and gamepad?terriblefire wrote: Sat Jun 06, 2020 5:18 pm Added the cap and now i have working USB keyboard
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
can i ask for one thing first.. explicitly set every unused pin to high Z.arkadiusz.makarenko wrote: Sat Jun 06, 2020 6:06 pmOnly those required for mouse and gamepad?terriblefire wrote: Sat Jun 06, 2020 5:18 pm Added the cap and now i have working USB keyboard
- Moderator Team
Are those lines 5V or 3.3V?terriblefire wrote: Sat Jun 06, 2020 6:19 pmcan i ask for one thing first.. explicitly set every unused pin to high Z.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
All the amiga lines are 5v. The ones that are INTSIG are 3.3varkadiusz.makarenko wrote: Sat Jun 06, 2020 6:29 pmAre those lines 5V or 3.3V?terriblefire wrote: Sat Jun 06, 2020 6:19 pm
- Moderator Team
@terriblefire
I've set up all pins (sorry don't know exactly which ones are not in use - will tidy this up later) to GPIO_Input no-pull-up no-pull-down. Which should be high impeadance.
I have still usart5 on PD2 - RX and PC12 - TX ? should this be changed as well?
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
no those are fine. Just things on the Amiga bus really.
