TF CD32 Riser Revision 2 Design Complete
TF CD32 Riser
Re: TF CD32 Riser Revision 2 Design Complete
arkadiusz.makarenko wrote: 22 May 2020 12:36
terriblefire wrote: 22 May 2020 10:29
I will fire over the CPLD firmware.. Its very basic and just passes PUNT via the CPLD at this stage.
Great.
What cpld do I need 144?
and if you had some time could you tell me what resistors I need to change/fit to get video out working?
CPLD is a XC9572VQ64
All the resistors that are there need to come off and 3 0R resistors need to go on.. i'll post a picture of what to change later.
arkadiusz.makarenko
Post by arkadiusz.makarenko »
I redone some stuff in amiga.c to make sure we don't miss any depressed keys. Works ok. I haven't noticed any issues on Doom or Pinball Dreams (and Amiga Test Kit)
Need to still test keyboard reset.
PS.
Code is dirty and inefficient, but works.
EDIT.
CPLD in place I even didn't know that I still have 4 spare ...
keyboard reset works ok.
I still haven't managed to crash either cd32 or ARM ... :)
~ Stanislaw Lem
wairnair
Post by wairnair »
Hi guys,
Will this riser support VGA out or "just" DB23?
Thank you
arkadiusz.makarenko
wairnair wrote: 23 May 2020 07:22 Hi guys,
Thank you
DB23 only.
~ Stanislaw Lem
I was on the fence for the VGA vs DB23 but most people just wanted DB23.
It would be the same thing at a signal level anyway.
matt020
Post by matt020 »
By going with DB23, we then have to add a buffered RGB --> VGA adapter anyway.
Could buffers be added and then a VGA 15 pin connector be offered. Would save the need for an additional adapter....
arkadiusz.makarenko
matt020 wrote: 23 May 2020 12:38 By going with DB23, we then have to add a buffered RGB --> VGA adapter anyway.
It is open source project. Anyone can to modify it, if they wish.
~ Stanislaw Lem
Im considering a buffer anyway but i'm not going to do any converters. Too many things already on my plate.
matt020
Post by matt020 »
terriblefire wrote: 23 May 2020 14:43 Im considering a buffer anyway but i'm not going to do any converters. Too many things already on my plate.
Yeah I probably worded that poorly, I meant the buffers and 15 pin connector only...
I think given that i'm going to pull the video of EXT_A[RGB] it probably wise to buffer. What i'll end up with is buffered DB23 most likely.
Return to “TF CD32 Riser”
Users browsing this forum: CCBot and 5 guests
