TF536 Rev 2 Design Complete (all gone)
68030 + SDRAM + IDE
PaulJ_2.0
Re: TF536 Rev 2 Design Complete (all gone)
Post by PaulJ_2.0 »
Woohoo mine arrived today, it seems the delay was due to it being sent to number 11 instead of number 111 :lol:
Looks really nicely done on the underside, for sure that is the way forward. The time saving alone is worth the cost of the card.
I'm a bit busy with other stuff today, but should be able to make a start on it tomorrow, so fingers crossed I will be pimping my SMD 500+ with this beauty.
PaulJ_2.0
Post by PaulJ_2.0 »
I'm such a knobbler!
I had everything ready, started to build it and it wow nice, it almost falls together! Having the underside prebuilt is a great time saver.
Anyhow, I get to the very last component, the oscillator and realise its supposed to be 100mhz. Doh, I only have 50 :(
RS should be delivering one tomorrow...
Great work on this though Stephen, it really is a nice looking and well designed board.
PaulJ_2.0 wrote: Wed Apr 22, 2020 5:29 pm Great work on this though Stephen, it really is a nice looking and well designed board.
A lot of effort went into making it simple and easy to build
theq
Post by theq »
Yeah, received mine and soldered it yesterday.
Top notch!
Subzero79
Post by Subzero79 »
theq wrote: Thu Apr 23, 2020 5:14 am Yeah, received mine and soldered it yesterday.
Top notch!
Mine not arrived yet due to lockdown but eae show us some pron
LADmachining
Post by LADmachining »
Managed to find a few minutes between household duties to get the CPLD soldered and programmed. Just RAM, CPU socket, buffers and header pins to go.
PaulJ_2.0
Post by PaulJ_2.0 »
terriblefire wrote: Fri Apr 17, 2020 3:04 pm Suppose i'd better share my alpha firmware
tf536r2_main_top_test.zip
Does this work ok with the buffered IDE?
I didnt get the IDE to recognise at all, so I removed IC4/5/6, replaced the 0 ohm resistors and it booted fine.
mine was built without the buffer which as you say works fine. Not tried with.
PaulJ_2.0 wrote: Thu Apr 23, 2020 9:08 pm
I have no interest in buffered IDE so i havent tried it. I basically copied a circuit from an IDE buffer setup but this is as far as i'm prepared to go with it.
PaulJ_2.0
Post by PaulJ_2.0 »
terriblefire wrote: Thu Apr 23, 2020 10:29 pm I have no interest in buffered IDE so i havent tried it. I basically copied a circuit from an IDE buffer setup but this is as far as i'm prepared to go with it.
Ah ok :)
Return to “TF536”
