@Danoo I think you'll be the first yo try 128mb.
Terriblefire said a couple of weeks ago that the current firmware will support 128 64 and 32mb. I have sone 32mb chips on some old simms for instance.
TF536 Rev 2 Design Complete (all gone)
Re: TF536 Rev 2 Design Complete (all gone)
Thanks for the info, I thought I had read that somewhere, will probably give it a crack on one of the boards, just need the slow boat to OZ to use a bit more sailPhilC wrote: Sun Jun 21, 2020 9:16 am @Danoo I think you'll be the first yo try 128mb.
Life is really simple, but we insist on making it complicated - Confucius
- Admin sponsor
Dont panic if you only see 64mb.. it will be easy to sort.Danoo wrote: Sun Jun 21, 2020 10:20 amThanks for the info, I thought I had read that somewhere, will probably give it a crack on one of the boards, just need the slow boat to OZ to use a bit more sailPhilC wrote: Sun Jun 21, 2020 9:16 am @Danoo I think you'll be the first yo try 128mb.
Terriblefire said a couple of weeks ago that the current firmware will support 128 64 and 32mb. I have sone 32mb chips on some old simms for instance.![]()
