TF536 Rev 2 Design Complete (all gone)
LADmachining
Re: TF536 Rev 2 Design Complete (all gone)
No solder whiskers between any pads?
- Admin sponsor
I'll send you one when i the bulk order arrives. I've never seen a dead short like that from JLCPCB they test them before they get sent out.Subzero79 wrote: 08 May 2020 14:11 Beetween gng and 3.3 volts i measure 1.1 ohm is normal
Removed all ics exept cpld and measures 1 ohm or is board defect?
Unsolder all parts pcb defective short beetween gnd and 3.3
@ terriblefire need a new one
Subzero79
One plus one i want to buy
- Admin sponsor
you tried putting 12V on the 3.3v line with all components removed and see if it burns away?
- Admin sponsor
@LADmachining did you get anywhere with testing
LADmachining
Are you sure you want to do that? Check his username! ;)
- Admin sponsor
You will have a brief terriblefire. Then it should clear the short.
My H6632B is good for this. When that runs out of amps i use a car battery.
@Subzero79 if you get photos of the defect for me i'll be able to get a refund from JLCPCB.
LADmachining
I have not yet found any open or short circuits on the board.
The last thing I can think is that I have somehow killed the CPLD. It was bought from RS, and soldered at a grounded workstation, so not sure what is going on. I have another new spare, so I could try swapping them over.
Apologies for holding up progress on the TF536, I am struggling to find much free time to get into the workshop.
Anthony
- Admin sponsor
No worries. I'm hovering over the trigger button on a 150 pc order so i'm keen to figure out issues before i do.LADmachining wrote: 09 May 2020 10:30I have not yet found any open or short circuits on the board.
Apologies for holding up progress on this, I am struggling to find much free time to get into the workshop.
Anthony
Users browsing this forum: CCBot and 42 guests
