Yes.dragmar wrote: Tue Jun 09, 2020 9:43 am IDE V1.1 R1C - LED 5V?
Do you also need to use PLD connections in this board?
EXXOS IDE V1.1 R1C BUILD & INSTALL INFORMATION
Re: EXXOS IDE V1.1 R1C BUILD & INSTALL INFORMATION
PCB solder. I put pictures, and I have a request, if I installed something wrong, I ask for information.
hi
is the parts list still current if fitting to an stfm.
cheers
cheers
No difference from a STFM to H4.philbo34 wrote: Sat Jun 27, 2020 7:18 pm hi
cheers
@dragmar - I can't see anything out of place from the photos at first glance.dragmar wrote: Wed Jun 10, 2020 10:20 pm PCB solder. I put pictures, and I have a request, if I installed something wrong, I ask for information.
Do you have the ACSI_10 header pin soldered in. I could not see it from the photo. Its the one to the top left of the large PLD.
forgive the prob stupid questions
are the resistors 1/4 watt
what type are the majority of the caps .
cheers
cheers
0.25 W is fine for the resistors. Everything except C8 are just little ceramic caps (at least on my build), and C8 is an electrolytic.philbo34 wrote: Tue Aug 04, 2020 5:26 am forgive the prob stupid questions
cheers
cheers for info
thecaver99
ivw ordered one of the bare boards just out of curiosity where would i get the image for the 27c4096 eprom or is it a matter of loading 1 image in low and other in hi space and is there anything i need to do to the roms?
looking forward to building and installing it into my stfm once i get it fixed
TOS images are here. https://www.exxosforum.co.uk/forum/viewt ... f=25&t=116 program 2 normally TOS104 TOS206 into it.
