Mega ST ROM swap - 2 chip to 6 chip.
Upgrade or replace the ROM.
Re: Mega ST ROM swap - 2 chip to 6 chip.
coonsgm wrote: 10 Sep 2024 14:05 I'm not too concerned...not a whole lot of reason to ever use two ROM TOS. Working with 6 ROM's is what's needed.
Well actual EPROMs that work with a 2 ROM setup seem to be thin on the ground unless you build some sort of adapter, so for me and my large stock of 27C256's, 6 chip is always the way forwards.
Working is working.
RB80atari
Post by RB80atari »
Thanks for this great tutorial Jonnie.
Just wanted to add, much like coonsgm my Mega 1 would not boot until i removed the 74LS11 chip.
As soon as i desoldered it, booted straight away no problems.
I also found a service bulletin that Atari put out and they do say that it needs to be removed.
Strange that it that it worked for you left on the motherboard!
Return to “ROM UPGRADES”
Users browsing this forum: CCBot and 12 guests
