JezC H4 Build - in slow time
Re: JezC H4 Build - in slow time
Post by JezC »
PhilC wrote: 29 Aug 2021 23:18 @JezC if you're struggling, I'm happy to take a look at some point?
@PhilC Appreciate the kind offer... I'll have a bit of a probe around to see if I can spot anything obvious (and try to hone my diagnostic skills in the process!).
If I don't make any progress then I will send it your way!
:2k2:
I think the most likely cause is that the keyboard slipped & pulled the connector off the pins on the mobo...so I had to straighten the pins.
Post by JezC »
And we have progress!
Over 2 months since I broke it...I finally managed to finish the fault-finding & get it back to some level of a working state!
Turns out that one of the large SMT capacitors had failed short circuit (which has happened to @exxos on one of his boards IIRC), so I've finally managed to remove that & the machine now boots once more.
Sadly, when removing a couple of the ICs (one 6850 & the 2149F) the sockets have failed so they need replacing before I do much more...but we have a resurrected H4!
Next step will be to fit the floppy drive/Gotek and then try to see what is different between my H5 and this (currently working) H4...
I now need to be careful not to make a habit of this or @PhilC will be out for revenge! ;)
Post by JezC »
One other "minor" irritation during the above is that the old LCD TV that I've been using for my H4/H5 investigations has decided to stop powering up... :headbang:
It now sits there with the power LED coming on briefly & then flicking off again, so I suspect a cap has succumbed to age.
Rather than get diverted by this new catastrophe, I just moved over to the Benq monitor I usually use with the original machines & fortunately that works enough to prove the H4 is alive.
I'd vaguely remembered some comments about the UBE video adaptor not working on the H4/H5 (no 12v on the monitor socket on the H4/H5???) so I snaffled the Exxos one out of one of my Megas & that worked well enough for this first test.
JezC wrote: 08 Nov 2021 21:29 I'd vaguely remembered some comments about the UBE video adaptor not working on the H4/H5 (no 12v on the monitor socket on the H4/H5???) so I snaffled the Exxos one out of one of my Megas & that worked well enough for this first test.
They have 12V on the socket. Mine still need power to the chip on the ST2VGA board. I don't remember any comments about the UBE not working unless anyone else does ?
Post by JezC »
exxos wrote: 08 Nov 2021 21:53
Thought @terriblefire had a problem in his build thread? I'll check & add a link if I can find it...
EDIT: Link to TF build below with comment about UbeSwitch...
https://www.exxosforum.co.uk/forum/viewt ... =70#p39419
Post by JezC »
Ok, so I've tried both the Exxos 'value' VGA adaptor & the Ubeswitch version on my H4 & both seem to work just fine!
So, next planned job is to fit my Trudie board & get that working...then I'm hoping to solder in the cartridge port & try out a couple of MIDI programs, then maybe even re-fit my TF536 to see what will work on the 030 with all that RAM....
Now where did I put that CF card...
JezC wrote: 22 Nov 2021 22:22 Ok, so I've tried both the Exxos 'value' VGA adaptor & the Ubeswitch version on my H4 & both seem to work just fine!
:bravo:
H4 seems so long ago now :lol:
Wow, the first post in this thread was Feb 2020, it has really been a build in slow time!!
I have a couple of H4s to build, I'd better get on it so my finished one has company :)
Post by JezC »
exxos wrote: 23 Nov 2021 01:52 H4 seems so long ago now :lol:
Yes, though I do like the greater ease of working on the through hole parts compared to surface mount stuff (that's not a dig at the H5, more the fine pitch TQFP & BGA packages we use at work).
Just glad to be back to having it working again...and this time I'll try not to do a @PhilC and break it again...or at least not until I've got that H5 floppy issue sorted!
Post by JezC »
rubber_jonnie wrote: 23 Nov 2021 09:03 Wow, the first post in this thread was Feb 2020, it has really been a build in slow time!!
I did get it first working back in June 2020, so not quite that long really...it's just that I broke it earlier this year :oops: when trying to sort out some issues with the first H5 build (getting there, though the floppy issue is still not resolved yet). :roll:
I still have one H4 and an H5B1 to build at some point (plus the second TF536...waiting on PLD & DRAM courtesy of the global shortages).
Maybe it should be a friendly competition to see who builds up their next system first? Spoiler alert - it's almost certain to be you! :lol:
Users browsing this forum: CCBot and 9 guests
