Stuff and Things.
Re: Stuff and Things.
Very nice does it need a recap ?
Tom
Tom
Not sure, it hasn't arrived yet, those pics are just stolen from eBay...
I'll certaninly be giving it the once over for stuff like that though.
Don't forget to get a Master System cart adapter too.
Adding a 50/60 switch with region change will be another little fun task.
I'll have a look at that, and want some sort of SD solution too.
I saw those on eBay, will probably have a look at that once I have it running nicely.Higgy wrote: Wed Nov 02, 2022 7:56 am Adding a 50/60 switch with region change will be another little fun task.
SD solution will also do Master System ROMs so adaptor is not needed unless you have a load of carts.
Ah you don't need eBay for the 50/60, just a few switches needed unless you want it to change a bit more fancy.
I use this site for all my 50/60 and RGB mods:
https://mmmonkey.co.uk/
Although his old site was better for finding guides, but not as visually impressive.
Cool thanks, I will take a look once I've got itHiggy wrote: Thu Nov 03, 2022 9:14 am SD solution will also do Master System ROMs so adaptor is not needed unless you have a load of carts.
With regards to carts, I tend to just use SD solutions where I can as I don't have the storage for lots of carts, so I guess once I get the SD solution I'll be golden. I just wanted the Sonic cart as it came with the MD I had back in the day
Good to know, that's another thing to add to my cart.........Higgy wrote: Thu Nov 03, 2022 9:14 am SD solution will also do Master System ROMs so adaptor is not needed unless you have a load of carts.
Well, the controllers and Sonic cartridge arrived, and boom!!
All working lovely
All I needed to do was clean up the cartridge edge connector and it powered on perfectly
Currently it's just a bare board on my workbench as I'm giving the case a good clean, but I fully expect it to look and run great once it's finished.
I'm only running it on RF out at the moment, so I need to sort out a proper cable to verify if the AV out port is not right as described, but so far so good.
All working lovely
