Stuff and Things.
Re: Stuff and Things.
Wow, unbelieveable!! After 40+ years of collecting computer bits,cables etc I have NOTHING in the shape of an RJ12 cable with 6 wires end to end. I have RJ11's all over the place. Not only that, I have no sockets I can rob to re-use!!
Grr, trying to minimise ordering stuff!!
@rubber_jonnie Always the case
I got a huge box of cables.. Will have every cable known to man other than the one I want.
RJ, did you name all the cables after yourself? RJ this... RJ that ....rubber_jonnie wrote: Fri Mar 20, 2020 8:26 pm Wow, unbelieveable!! After 40+ years of collecting computer bits,cables etc I have NOTHING in the shape of an RJ12 cable with 6 wires end to end. I have RJ11's all over the place. Not only that, I have no sockets I can rob to re-use!!
@rubber_jonnie I have some plugs for mega leads somewhere, the crimp on type.
I can send you some if youd like?
I need to find them to make myself a new lead.
@PaulJ Did you only just notice?PaulJ wrote: Fri Mar 20, 2020 9:53 pmRJ, did you name all the cables after yourself? RJ this... RJ that ....rubber_jonnie wrote: Fri Mar 20, 2020 8:26 pm Wow, unbelieveable!! After 40+ years of collecting computer bits,cables etc I have NOTHING in the shape of an RJ12 cable with 6 wires end to end. I have RJ11's all over the place. Not only that, I have no sockets I can rob to re-use!!
Grr, trying to minimise ordering stuff!!![]()
@PhilC Thanks,that's very generous but I have ordered some. Also fairly sure my crimp only does RJ45'sPhilC wrote: Fri Mar 20, 2020 9:59 pm @rubber_jonnie I have some plugs for mega leads somewhere, the crimp on type.
Ya, pretty much asleep at the switch.
Budget cables done dollar store style I got some telphone cables curled cable from the dollar store cut the ends of and put pin crip rj12 on them total cost 1.25
Tom
Tom
I did the same but with ps/2 extension leadsTomswork wrote: Sat Mar 21, 2020 6:54 am Budget cables done dollar store style I got some telphone cables curled cable from the dollar store cut the ends of and put pin crip rj12 on them total cost 1.25
Tom
