Stuff and Things.
PaulJ
Re: Stuff and Things.
Post by PaulJ »
rubber_jonnie wrote: 06 Apr 2021 22:02
PaulJ wrote: 06 Apr 2021 14:40 Yes, was using telnet, tried a ping with no response.. maybe a mega doesn’t even do ping? Also traceroute doesn’t get there either so I’ll chalk the experience up to the opportunity to build telnet on the new machine. It was more a novelty to check it out anyway so not a great lost. I use telnet quite a bit and hadn’t bothered to install it yet.
Weird, works fine on my Mac, what machine did you try on?
I'm using a Mac Pro 6,1. Does the site have a max number of users? Does the site return ping requests? I'll try again later.
PaulJ wrote: 06 Apr 2021 22:16
I'm using a Mac Pro 6,1. Does the site have a max number of users? Does the site return ping requests. I'll try again later.
I don't think so, I've never tried to connect and been rejected due to a user limit. As for ping, no they don't respond.
As I said I'm using my MacBook Pro 9,2 however I didn't install telnet, I downloaded Welly instead and it works just fine set up as a site in that.
PaulJ
Post by PaulJ »
@rubber_jonnie , just upgraded the trashcan from Mojave to Big Sir. No issues and Hatari 2.31 runs fine.:coffee:
PaulJ wrote: 08 Apr 2021 23:24 @rubber_jonnie , just upgraded the trashcan from Mojave to Big Sir. No issues and Hatari 2.31 runs fine.:coffee:
I don't think it's so much my install of Hatari, it's the files in Onedrive it doesn't like. If I download fresh files straight from the web to the Mac, it seems to run just fine.
I'm finding that zips, pdfs, Word, Excel et al from Onedrive are universally disliked by my Mac, even when copied from OD to my Downloads folder, but anything new is just fine.
PaulJ
Post by PaulJ »
rubber_jonnie wrote: 08 Apr 2021 23:34 I don't think it's so much my install of Hatari, it's the files in Onedrive it doesn't like. If I download fresh files straight from the web to the Mac, it seems to run just fine.
Well Jon... it is MS. I'm sure they know better about the files you stored there than you do. They do force upgrades on the poor windoze users that brick machines.. erase files etc.
PaulJ wrote: 09 Apr 2021 00:06
It's funny, but I've never really had issues with MS and I've been using them since the days of DOS. I don't doubt other people have had problems, but then I could moan about Apple where it seems to have decided that you will have certain options set back to Apple defaults on every iPad and iPhone update. My wife will put off her updates as long as possible because of it.
As for Mac OS, well I can't say, I just don't have the experience, but so far I do think the pairing of OS and hardware does work really well though, I mean to think my 9 yr old MBP would be performing as well as it does and on a par with my XPS 15 is a shocker.
Going to look into the OD on Catalina subject, because I can't even open files I've copied from there.
Oh, and I may consider an MBP M1 for my next machine, but I really want 2nd generation to arrive before I consider it.
rubber_jonnie wrote: 09 Apr 2021 09:02 Oh, and I may consider an MBP M1 for my next machine, but I really want 2nd generation to arrive before I consider it.
Yeah, never go for the first iteration of hardware. People who went for the first gen Intel Macs were burned by that as Apple dropped support for 32 bit x86 pretty darned quickly.
stephen_usher wrote: 09 Apr 2021 09:11
Quite. I had a 1st revision Orange SPV smartphone, and it did all kinds of weird stuff, so I went back to Nokia for a while and waited for a few iterations of Android before going in.
derkom
Post by derkom »
The M1x machines will be arriving in the fall, and I'm sure going to feel tempted by those.
derkom wrote: 09 Apr 2021 10:53
I'll likely wait until this sort of time next year, maybe a bit later in September, since I really don't need a new laptop right now, plus we have a new house to pay for in 3 months!
Currently as well as my MBP I also have a Dell XPS 15 with 1 TB of storage and 32GB RAM, so I don't need something newer, but It will have to happen in a bit. For a start I do want to retire my Windows domain and a move to Mac only would make that an easier pill to swalllow. I guess we'll see!
Users browsing this forum: CCBot, Google [Bot] and 16 guests
