Stuff and Things.
Re: Stuff and Things.
HigashiJun wrote: Thu Aug 20, 2026 12:26 pm Love it !
You're really busy everyday.
:D
I try to fit things in around works since I work from home :)
One more CPLD soldered on, should have all of them on the PCBs by the end of the day, though I can't finish any more until my parts orders arrive. I can get partial builds done though.
Need to get some more of the PCB built for the Atom and I do have parts for that.
So I ran out of parts for the standard RGB2HDMI builds and decided to crack on with the Atom RGB2HDMI build.
It's coming along nicely:
But now I'm in the same position with that...
More parts on order, hopefully I'll be able to get them all finished before I go on holiday to France in a couple of weeks.
More as and when parts arrive :)
OK, so parts arrived for the RGB2HDMI boards:
So that means the 3 remaining boards will be completed today, leaving just the 40 pin connectors for the RPi which are the last part required, fingers crossed they'll come before I go away for the weekend.
Once they are all built I'll do a bulk test to be sure they all work as expected.
No parts for the Atom2HDMI board as yet, but they are all on order. I still have the Atom Colour board as well.
I also put a sneaky low bid in on this:
Screenshot 2026-08-24 at 11.26.28.png (907.29 KiB) Viewed 62 times
And I won. I don't know if it'll be repairable, but I'm going to give it a go and I do have another that works for reference when I get onto fixing it.
:dualthumbup:
As luck would have it, I realised I had some of the missing caps for the Atom2HDMI board, so they were populated over lunch, and I finished the last 3 RGB2HDMI boards too, bar the RPi connector.
Not much left to do on these boards now, looking forwards to getting them finished :)
OK, I finally did something with KiCad...
Screenshot 2026-08-25 at 15.55.48.png (69.38 KiB) Viewed 41 times
A small beginning but it did teach me a lot. Might drop the gerbers into PCBWay or JLCPCB to see what comes back :)
Is that a composite mod by any chance?
PhilC wrote: Tue Aug 25, 2026 4:36 pm Is that a composite mod by any chance?
It most certainly is :)
Decided it would be good to have a go at KiCad and this seemed like a good place to start. I also got fed up of building then on Veroboard :)
Looks good to me Jon. Could obviously be made smaller if needed but great first try.
PhilC wrote: Tue Aug 25, 2026 4:44 pm Looks good to me Jon. Could obviously be made smaller if needed but great first try.
Thanks.
That's not the actual size BTW, just a screengrab of the 3d viewer. Actual size is 19.5mm x 15mm, transistor is SOT23 and resistors are 0805.
