Stuff and Things.
Re: Stuff and Things.
Yeah, submitted the QL benchmark results. :-)
Nice :)
Small addon on for my Evercade EXP-R arrived yesterday @Icky
Of course if you have an older model without tate mode it's a bit irrelevant, but it is surprisingly comfortable to hold.
Since I had the SACK PC-Speed board on my workbench and my soldering iron was out, I got going on that as well as the Cosmac ELF II:
Very fast to build, I just need to get the missing sockets installed when they arrive and then I can see what parts I'm missing for the rest of the build.
Those are looking good @rubber_jonnie!
I was always wanting a h/w PC emulator BITD as PC-DITTO was soooo slow...
Maybe I should try PC-DITTO on a fast PC (emulate an ST emulating a PC.... because I can ;) ) or the DFB1X even...
I do have 4 spare boards for the PC-Speed build so if anyone is interested then give me a shout.JezC wrote: 31 Mar 2026 12:48 I was always wanting a h/w PC emulator BITD as PC-DITTO was soooo slow...
Going for Inception there :)JezC wrote: 31 Mar 2026 12:48 Maybe I should try PC-DITTO on a fast PC (emulate an ST emulating a PC.... because I can ;) ) or the DFB1X even...
My daily driver is a Macbook Pro, on which I also run Windows 11 under Parallels Desktop and under that I have run emulators like Hatari etc, so the concept is not unknown to me :)
Oooh, must have a look at that.rubber_jonnie wrote: 31 Mar 2026 09:28 Small addon on for my Evercade EXP-R arrived yesterday @Icky
Have you seen the new Evercade Nexus - https://evercade.co.uk/evercade-nexus/
Similar MacBook Pro with VMWare Fusion to run Linux Mint running Hatarirubber_jonnie wrote: 31 Mar 2026 13:06 My daily driver is a Macbook Pro, on which I also run Windows 11 under Parallels Desktop and under that I have run emulators like Hatari etc, so the concept is not unknown to me :)
I have recently been porting my VMWare images over to Proxmox PVE, I built a machine from a X99 motherboard to run all manner of VMs from OS/2 to BeOS etc.
Also I know you have a Evercade-VS as well have you seen these - https://funstock.co.uk/products/evercad ... controller
As it goes I hadn't, wish I'd known that was coming out 6 months ago!!!Icky wrote: 31 Mar 2026 20:13Oooh, must have a look at that.rubber_jonnie wrote: 31 Mar 2026 09:28 Small addon on for my Evercade EXP-R arrived yesterday @Icky
Users browsing this forum: CCBot, Icky and 25 guests
