So I need to try S-Video, and I think I have a one in my big box o cables. I will have a look after my bacon sandwich
Stuff and Things.
Re: Stuff and Things.
Composite direct and changes to aspect ratio made no difference :
Yeah, that does look like interference colours.
I found my S-Video cable and it only works in monchome...
Weird, the chroma is obviously broken.
I’m sure I used SVHS when I tested it
It 'may' be the cable, so I will get a C64 specific one as I don't recall what this cable was for.
Might also be worth doing a buzz test on it.
Could easily be my cable TBH.
OK, so new S-Video cable is on order for the C64.
As is an STM32F103C as I need to build a BlueSCSI fairly quick. My A5000 SCSI drive is getting pretty erratic, and I think it'll be a matter of time before the drive dies, so time to build a replacement.
Next, I need to stop shopping until payday...
- mrbombermillzy
If the cable is already busted, perhaps some wiggling or 'cramping' areas of the cable might connect the broken luma connection.
I've had plenty of badly stored cables (causing stretching and broken leads) in the past and this has worked on several occasions as a last resort.
Nice C64 BTW.
Nice C64 BTW.
Indeed it could be something like that, however I do store cables very carefully to avoid hard bends, but the I'll compare to the new cable when it arrives.mrbombermillzy wrote: Mon Jun 12, 2023 3:55 pm If the cable is already busted, perhaps some wiggling or 'cramping' areas of the cable might connect the broken luma connection.
Nice C64 BTW.
It is a nice C64 isn't it
