I appear to have killed my A1200 keyboard
8 Bit Dreams
- Moderator Team
Re: I appear to have killed my A1200 keyboard
Just want to add my 2cents - chaps name on Sellmyretro is Rich Mellor, knowing him and used his services for at least 13 years, always got an excellent quality products. He is very kind person, so may be worth to ask him what can be wrong with this membrane
- Admin sponsor
It wasn’t from him.
PaulJ_2.0
I had the idea a while back to make a thin pcb that slots in to the connector to act as a buffer, so you can save the wear on those crappy membranes.
I don't suppose anyone knows if a .4mm board will insert?
- Admin sponsor
The membrane ripped where it enters the keyboard.
I’ve ordered a USB adapter
arananet
im making a new membrane just like i did for the a600 on pcb (https://github.com/arananet/A600BlueKBMembranetoPCB). If you wait a little bit S it will be available soon.
PaulJ_2.0
That little header board is what I was talking about earlier. Do you sell them? Would save wear and tear on the membrane when constantly removing the keyboard.arananet wrote: 29 Jan 2020 12:12 im making a new membrane just like i did for the a600 on pcb (https://github.com/arananet/A600BlueKBMembranetoPCB). If you wait a little bit S it will be available soon.
Aeberbach
More permanent fix, and choose the way your keyboard feels by selecting the right switches:
https://github.com/aeberbach/A1200KB
This is the third revision of A1200 PCBs and I'm happy with it. Connects to A1200 mainboard with a 32-way ribbon cable and connector, these are still available from Mouse Electronics. All you have to do is trim off one of the connectors carefully with scissors. Mounts inside the A1200 case with 3D-printed rails.
- Admin sponsor
Looks good!
dalek
Wow that's a cool project! Any idea if he will make them source open/freely available?
I don't speak Polish but I do speak Gerber 8-)
Users browsing this forum: CCBot, Qwantbot and 1 guest
