For ones I am going to program infrequently I have just adapted a cable with pins and poke it into the plated holes. For a more permanent connection solder 0.1" headers and either use a PC motherboard USB A - header ready made cable or make one USB-dupont. Right angle headers if vertical space is an issue. You can fit them underneath - dupont connector will clear the SMT parts & should clear the ROM socket too - very neat wiring.terriblefire wrote: 21 Jan 2020 23:06 How are people wiring these up. I dont want to electro boom any.
Or solder wires straight to the board.
The USB pinout is also the same as the cheap USB micro breakout PCBs you can get from eBay 10 for £0.99 delivered. e.g. Much cheapness USB adapters
4/5 pin female 0.1" headers are cheap too.
The issue D boards do have reverse polarity protection on the USB (issue C you'd short via the ESD protection on VBUS). I don't recommend abusing the reverse protection but it is there in case of a 180 degree plug error.
