Help to configure ClassicWB3.9 with TF330
68030 + SDRAM + IDE
hardgb
Re: Help to configure ClassicWB3.9 with TF330
Post by hardgb »
supaduper wrote: Sat Jan 18, 2020 12:45 pm To stop the DF0 unreadable icon appearing on WorkBench edit your Startup-Sequence as I have done by adding this line before the first Setpach command
SetPatch NOROMUPDATE QUIET
First of all forgive me because this is my first time to open a post and thanks for the help.
I did this as you guided me more continuously in the same way.
hardgb
Post by hardgb »
Correcting: I tested it again and it worked, (I don't know why it didn't work soon).
I was impressed, as it solved both problems at once. I made a video to show.
https://www.youtube.com/watch?v=vA59n3Fb0Q4&t=13s
I just need to be able to configure Shapeshifter because it opened more and shows this error.
Return to “TF330”
