TF Riser Revision 0 Arrives
TF CD32 Riser
arkadiusz.makarenko
Re: TF Riser Revision 0 Arrives
Post by arkadiusz.makarenko »
terriblefire wrote: 10 Feb 2020 19:03
arkadiusz.makarenko wrote: 10 Feb 2020 15:37
Looked at datasheet of f105 and f730 pinout of LQFP64 package there is small difference only on pins 25-30 and different markings on Vss. So unfortunately it would not be direct replacement, but I don't think it would be major change. Can't see any requirement difference for oscillators (but I know shit about it, but Kier Fraser Greaseweezel works on 8Mhz crystal - Pierce oscillator circut), boot1, PB9 etc are in the same spot. They provided compatibility sheet in docs, but not for f10x series but only for f4x1 and F405/F415 series.
This would give second USB port basically for free. Just a thought.
MAX chip could be easier as porting code from MiST might be actually the quickest.
Another suggestion. By having access to PB6 and PB7 you could provide another mean of programming the chip (and way of getting serial feedback), just by adding GND and 5V next to it could help a little. This would allow of programming chip by USB FS port (need of USB A - USB A cable), serial via PB6 and 7 or ST-LINK SW.
Sure. Can you sketch out the circuit you want.
Sorry I cound't put much time into this lately.
Riser Rev 0 Build - still unsucessful.
I connected my cheap £5 logic analyser to usb port, and I can see that USB is being reset and when communication starts it is only for few ns and all stops. Both d+ and d- do their job, but everything stops. From chip perspective I can see that device is being discovered, but any means of communication fail after device request. So stm32 never gets descriptor data from device.
I did go through some information about usb library, and I did find out that changing two sections in library should help with amount of devices which can be used. Issue is that library expects that all sections of usb descriptors are populated, even non mandatory ones. Some devices do not provide it, so code loops over those like device was not supported. Easy fix by changing sections to check only if ubs is not busy, and this should help a little.
I am learning more on USB communications, this is primer to start working on controller support. It is going slowly just now as I have parents in law visiting just now.
Looked at f730 replacement, and it is most liekly just drop in replacement. Only one pin is being used on changed pins, and it is used to drive LED. So this is not an issue at all. I should get hid2ami pcb soon and I will test if I just can install f730 and if it can do basic stuff on USB FS.
~ Stanislaw Lem
arkadiusz.makarenko
I really really don't know what is going on.
I have just built HID2AMI, and I can see exactly the same issue.
I have just few items on the HID2AMI board. Regulator, MPU, crystal, 2 caps for oscillator circuit, few resistors, LED and one or two decoupling caps and USB connector.
~ Stanislaw Lem
arkadiusz.makarenko
F**K YEA!
OK.Partial success.
I changed chip to F730 (it is drop in replacement btw)
I managed to build firmware, and start device and get it registered!
But it can be done only on external source of power. If I run it out of 5V only I got weird behaviour with the chip. Like issues with debugger etc. It is not 100% stable.
EDIT.
New regulator, caps and complete erase of chips seems to solve all my issues.
~ Stanislaw Lem
sampedenawa
Post by sampedenawa »
arkadiusz.makarenko wrote: 15 Feb 2020 17:11 I really really don't know what is going on.
Did you check against proper clock settings for USB ?
USB stack needs a well defined clock configuration.
arkadiusz.makarenko
sampedenawa wrote: 16 Feb 2020 08:42
48Mhz on UBS, HSE from external 8mhz crystal/oscillator.
Anyway it does work on f730 chip. I can start working on firmware!
Ps. I reused f105 chip. I have suspicion that those are not that robust as I initially thought. I think I destroyed 2x f105 and a f730.
~ Stanislaw Lem
sampedenawa
arkadiusz.makarenko wrote: 16 Feb 2020 09:19
Hummm.. these are my settings for HID2AMI:
#define SYSCLK_FREQ_72MHz 72000000
/* Configure PLLs ------------------------------------------------------*/
/* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
/* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */
RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL | RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV2 | RCC_CFGR2_PLL2MUL10 | RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
// USB PRESCALER FOR 8MHZ EXT CRYSTAL
// PLL2CLK = ( 8 (HSE) / 2) * 10 = 40 MHZ
// PREDIV1CLK = PLL2 / 5 = 8 MHz
/* PLL configuration: PLLCLK = PREDIV1 * 9 = 72 MHz */
/* USB PRESCALER 1.5 for 8MHZ Crystal */
RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL | RCC_CFGR_OTGFSPRE);
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLMULL9);
RCC->CFGR &= (uint32_t)~RCC_CFGR_OTGFSPRE;
I had managed to get it all working with CubeMX and the f105... the code is in github with the riser schematics.
arkadiusz.makarenko
sampedenawa wrote: 16 Feb 2020 11:09
It was 100% hardware issue. I had damaged 2x f105 somehow.
I managed to set it up on f407 and f730 on dev boards and different devices without any issues at all.
I was just banging my head on this for so long, as it took me like 3 weeks to make this riser board to work.
~ Stanislaw Lem
arkadiusz.makarenko wrote: 16 Feb 2020 11:54 It was 100% hardware issue. I had damaged 2x f105 somehow.
Where did you get the Chips? I got mine from RS.
arkadiusz.makarenko
terriblefire wrote: 16 Feb 2020 12:03
First one from Mouser, but I damaged it very quickly. As I couldn't connect to flash at all.
Second once which was partially working was from eBay (Thinking about it, it could be fake! )
Working f730 is from Farnell.
~ Stanislaw Lem
Return to “TF CD32 Riser”
Users browsing this forum: Baidu [Spider], CCBot and 37 guests
