TF Riser Revision 0 Arrives
TF CD32 Riser
Re: TF Riser Revision 0 Arrives
However looks like the composite device is working ... well done.
OK if i was a betting man i'd say the CPLD isnt getting the mouse data at this point.
arkadiusz.makarenko
Post by arkadiusz.makarenko »
terriblefire wrote: Sat Mar 14, 2020 2:33 pm Ok no crashes but the mouse delta types are all screwed up from what i originally posted.
Mouse datacomes from the mouse as an unsigned byte which needs to be cast to a signed byte (128-255) -ve, (0-127) +ive...
this needs to be accumulated in the buffer as a signed 16 bit because you can get multiple mouse events per transmission to the amiga.
You accumulate this in a further layer to emulate joy0dat and joy1dat.
You are sending the raw joy0dat and joy1dats to the CPLD. its dumb and doesnt have the gates to do math.
Ok. That was a bug in casting int16_t to uint8_t.
Now it is returning values in ranges -128-127
But code at this point with populating mouse_delta is just looking at only left mouse button.
I will try to investigate if mouse data is leaving chip at all.
~ Stanislaw Lem
The CPLD is definitely not getting data for the mouse
arkadiusz.makarenko
terriblefire wrote: Sat Mar 14, 2020 8:01 pm The CPLD is definitely not getting data for the mouse
I can see that we do use SPI mouse and Keboard data as driven manually by writing directly using GPIO.
Maybe it is messing some registers at some point which are required for SPI?
~ Stanislaw Lem
Erm it’s a bit of a kludge at the moment. I think using the keyboard method to transmit the mouse data is maybe the way forward. I’ll sort this bit out.
arkadiusz.makarenko
terriblefire wrote: Sun Mar 15, 2020 11:54 am Erm it’s a bit of a kludge at the moment. I think using the keyboard method to transmit the mouse data is maybe the way forward. I’ll sort this bit out.
I pushed bugfix re mouse readings to my repository. It is just change to two lines of code.
I will try to extend gamepad support then. At this moment it works only for standard HID PC gamepads. Will try extend it to Xbox360, ps2/3/4 gamepad as well, as they are most common (I think)
I will skip hub support for now, I dont think we have enough ram for this on f105.
~ Stanislaw Lem
Tbh I’m going to swap my ARM for a bigger chip and make some changes to how keyboard works.
I think i have enough info to make a rev1 now
arkadiusz.makarenko
terriblefire wrote: Sun Mar 15, 2020 1:38 pm Tbh I’m going to swap my ARM for a bigger chip and make some changes to how keyboard works.
Which chip do you have in mind?
~ Stanislaw Lem
The 4xx dual USB one you’ve been using
Return to “TF CD32 Riser”
