68060 sources
viking272
Re: 68060 sources
Thanks Stephen, good to know. 👍
peters
Re: 68060 sources
I was just trying to find a pdf I downloaded last year describing an airliner avionics system that used a 68060.
chue
Re: 68060 sources
I don't know how well it works on through hole components, but maybe try some low temp solder? Brand name is Chip Quik, but there is no-name stuff as well.viking272 wrote: 02 Feb 2024 14:24 So I had a go with the heat gun, 450c setting, moving it over the underside on the soldered pins.
My test solder went soft and stuck to the pcb.
I pulled at the chip gently from the main side, nothing.
Went back for another minute. Everything on the board seemed super hot but no movement from the 68060.
Should I keep going or is there another method?
peters
Aeberbach
Re: 68060 sources
I'm fairly sure they are not full 060s
Principal ASIC Engineer - SystemVerilog, VHDL
STf,STfm,STe,MegaST,MegaSTe,Falcon060
viking272
Re: 68060 sources
If you look on p.11 of this chat I bought an almost identical one
cloverskull
Re: 68060 sources
Hey @terriblefire I was just reading through this thread and wanted to ask if you were still looking at doing a 68060 in FPGA? How's that going? With the current prices of legit 68060s and the dodgy scam markets for these things, an FPGA would be perfect.
- Admin sponsor
Re: 68060 sources
I've said this before. I dont think FPGAs are the way forward nowadays. Something like PiStorm or Buffee is the more efficient route to a 060 replacement.cloverskull wrote: 08 Mar 2024 21:17 Hey @terriblefire I was just reading through this thread and wanted to ask if you were still looking at doing a 68060 in FPGA? How's that going? With the current prices of legit 68060s and the dodgy scam markets for these things, an FPGA would be perfect.
But TBH I've too many projects happening to look at CPU replacements at the moment.
Re: 68060 sources
Is Buffee actually getting anywhere? The last update I saw was last May.
Users browsing this forum: CCBot and 3 guests
