I found this program called RESOUND which plays a sound file of HAL when you exit a program and at system startup. It would be great if I could convert my own movie/sound clip.
Converting a WAV, MP3 etc to an SND file.
- Cosmic Puppet
- Cosmic Puppet
Re: Converting a WAV, MP3 etc to an SND file.
I've had a nothing day, so I've figured this out using Adobe Audition:
1. Load up your sound clip.
2. Select Convert Sample Type.
3. Select these settings and save.
4. Converted clip will look like this.
5. Save as PCM Raw Data file.
6. Place your sound clip in Atari Root Directory with the RESOUND.INF file.
7. Edit RESOUND.INF file accordingly and save.
Have fun!
Have fun!
- Cosmic Puppet
Re: Converting a WAV, MP3 etc to an SND file. *UPDATE*
It's best to use 9.6 KHz.
I found that using 30.7 KHz caused the Monochrome Millipede game to crash, showing four bombs. The other sample rates above 9.6 KHz created more artifacts whilst loading.
I also noted that shorter clips are "safer" too.
"Do you feel it Crawford?"
