Limited TF536 Run - Sort of Sales (All gone)
68030 + SDRAM + IDE
arkadiusz.makarenko
Re: Limited TF536 Run - Sort of Sales (All gone)
Post by arkadiusz.makarenko »
terriblefire wrote: Tue Jan 28, 2020 9:26 pm
arkadiusz.makarenko wrote: Tue Jan 28, 2020 9:07 pm My TF536 is stable under Diagrom.
I am still troubleshooting build.
Forgot that 4 layer board are pain to solder correctly. I really need to invest in better soldering station.
Yeah you really need a basic temperature controlled iron and always use the "proper" amount of flux
Weird. I can start diagrom and all mem test ok (on fast test and 5mb slow reported ok before skipping it), but can't start normal kickstart 3.1
~ Stanislaw Lem
arkadiusz.makarenko wrote: Tue Jan 28, 2020 9:36 pm
Slow ram?
Can you edit memory manually at 0x40000000?
arkadiusz.makarenko
terriblefire wrote: Tue Jan 28, 2020 9:50 pm
Slow ram?
Sorry. It was slow test option on manual mem test.
It takes ages to test 64mb.
It must be dry solder somwhere.
~ Stanislaw Lem
kludge
Post by kludge »
I’ve had that with TF534. Diagrom doesn’t test the RAM 100%, and the Kickstart power on routine does some other tests. For me it was a bridge or floating pin or something like that.
Try putting KS 1.3 on there just to see if it boots. 1.3 doesn’t test the memory as thoroughly as the later versions do.
I think Stephen made a special firmware build for me that didn’t autoconfig the fast ram, so that I could boot on a floppy and then add the RAM with addmem and run AmigaTestKit to figure out where the fault was.
My lack of focus:
arkadiusz.makarenko
Got my TF536 booting to workbench now.
Cpld and CPU is not getting hot.
~ Stanislaw Lem
arkadiusz.makarenko wrote: Wed Jan 29, 2020 10:21 am Got my TF536 booting to workbench now.
What was up?
arkadiusz.makarenko
terriblefire wrote: Wed Jan 29, 2020 12:45 pm
What was up?
It had to be soldering on cpld.
It seems that I still have some issues. Looks like my hdd image, as everything is ok from floppy.
EDIT: yes partition is corrupted. Need to set it up again.
~ Stanislaw Lem
The CPLDs are v difficult without magnification
Justme14
Post by Justme14 »
Hi ,
I finally received the 2 missing IC and soldered them,TF536 is now finished.
Did a run whith Frontier for 2 hours , no crash
IDE preformance seems slow get only just 1 mb , but with fastrom option , I get even more then 4 MB and Workbench feels rather snapy then.
Some Sysinfo Pics
!Message from: Moderator
@Justme14, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
Looks like a winner.
any major changes requested?
Return to “TF536”
