Limited TF536 Run - Sort of Sales (All gone)
68030 + SDRAM + IDE
alenppc
Re: Limited TF536 Run - Sort of Sales (All gone)
Post by alenppc »
PhilC wrote: 24 Jan 2020 21:02 OOpps, so I've made a boo boo.
I've bought and soldered on a XC95144XL-10TQG144I instead of the 288. Will the firmware fit into the 144 with 64mb ram?
Nope, you need a 288
That's what I thought, thanks for confirming.
Money will be running next pay day then.
alenppc
Post by alenppc »
IDE speed on the 536:
mattymuc
Post by mattymuc »
How is it possible that IDE is so much faster on your card than on mine?
I have tried different compact flash cards, there's no difference.
I will test it in an A500 mainboard tomorrow.
alenppc
Post by alenppc »
mattymuc wrote: 24 Jan 2020 22:03 How is it possible that IDE is so much faster on your card than on mine?
My bet is that you have a short somewhere... The CPLD shouldn't be getting hot.
mattymuc
Post by mattymuc »
There is definitely no short circuit!
go0se
Post by go0se »
Can you post close up photos of your CF adapter. Both sides if possible.
Justme14
Post by Justme14 »
Hi ,
Received my board In the mailbox yesterday and started soldering today.
Saddly I could not finished the board, as I ordered 4 of FET switched IC ,but actually needed 6 :roll: .
Board already starts ok with Diagrom.. but offcourse without fastram.. :D
Anyway,I orded some extra Fet Switched IC and hope to finish it next week.... will post again for the result..
arkadiusz.makarenko
Post by arkadiusz.makarenko »
I was hoping to get my parts from Mouser last night, unfortunately parcel was stuck on London airport fro 2 days.
So most likely posts will be delivered on Monday. So I will have time to build card next weekend.
~ Stanislaw Lem
Customs waits are the hell of getting stuff from the 'States. It's usually about 4 days, plus more if you have to pay duty.
Return to “TF536”
Users browsing this forum: CCBot, petal [bot] and 4 guests
