Limited TF536 Run - Sort of Sales (All gone)
68030 + SDRAM + IDE
Re: Limited TF536 Run - Sort of Sales (All gone)
Well done guys, certainly gives me confidence to get mine all built up when the parts arrive tomorrow.
Awesome.. i was worried i was letting a gene out of the bottle with this run.
alenppc
Post by alenppc »
terriblefire wrote: 19 Jan 2020 17:42 Awesome.. i was worried i was letting a gene out of the bottle with this run.
Let's see how it works for others that had no issues with the original firmware. It is weird how on some machines it worked, but not on others.
8 Bit Dreams
Post by 8 Bit Dreams »
Will try this fw, however i was pretty happy with CDTV compatible ;)
go0se
Post by go0se »
I'm having issues with the tf536r1_main_top_FULL_PHASE_7 that didn't occur with the original tf536r1_main_top.jed
WHDLoad games drop out sporadically and suffer from graphic artifacts when running :
go0se
Post by go0se »
Also can anyone confirm the correct value for C13? It's listed as 0.1UF 0603 in the BOM but the footprint on the board is for a 1206. Looks like I just threw a 0.1uf 1206 on without paying attention during the build.
PaulJ_2.0
Post by PaulJ_2.0 »
go0se wrote: 19 Jan 2020 18:57 Also can anyone confirm the correct value for C13? It's listed as 0.1UF 0603 in the BOM but the footprint on the board is for a 1206. Looks like I just threw a 0.1uf 1206 on without paying attention during the build.
I've used .33uf on c12-c15
PaulJ_2.0
Post by PaulJ_2.0 »
Oh right I think you mean C18 (screen printing isnt clear)
That's 10uf 1206.
C13 is definitely a 0603.. its one of the level shifer caps.
PaulJ_2.0
Post by PaulJ_2.0 »
go0se wrote: 19 Jan 2020 18:52 I'm having issues with the tf536r1_main_top_FULL_PHASE_7 that didn't occur with the original tf536r1_main_top.jed
I've not had any problems like that at all.
Have you checked your ram? I use this:
https://archive.org/details/Advanced_Am ... _Australia
You can place the executable on your HDD and run from there or just boot to floppy.
I find it to be very good, once i get a full pass on that I move onto something else than the ram and it's never been wrong.
Return to “TF536”
Users browsing this forum: CCBot and 19 guests
