Limited TF536 Run - Sort of Sales (All gone)
PaulJ_2.0
Re: Limited TF536 Run - Sort of Sales (All gone)
2xBlack and 2xGold all same problem, need cooling on CPLD or crash within 10 seconds.
- Admin sponsor
But no cooling on DiagROM?PaulJ_2.0 wrote: 18 Jan 2020 10:02 2xBlack and 2xGold all same problem, need cooling on CPLD or crash within 10 seconds.
How strange.. Ok let me try one more thing to send you.
PaulJ_2.0
Original FW needs cooling in Diagrom or it hangs on memory detection while starting up.
All of these new ones detect fine in Diagrom.
Thanks for the hard work guys. I've ordered my parts which will be here Monday. I've ordered the I cpld but can order some C variants if that helps too?
- Admin sponsor
Try this one.. I have screwed around with it a bit to be able to parameterize some things so it may simply not work..PaulJ_2.0 wrote: 18 Jan 2020 10:10Original FW needs cooling in Diagrom or it hangs on memory detection while starting up.
I've removed all the CDTV rom patches and changed some power settings.
In other news if you are an Atari ST user i've parameterized out the interrupt/gayle crap so you could use a 144 CPLD.
PaulJ_2.0
No KS Screen
In Diagrom, detects memory fine uncooled but no keyboard and graphical glitches (odd blocks appear randomly).
- Admin sponsor
Ok I suppose i better pack the AGA machines away and haul out a 500.PaulJ_2.0 wrote: 18 Jan 2020 10:28 No KS Screen
Give me an hour..
Tried the board in a ST?
PaulJ_2.0
No, I only have Amigas but all revisions of 500.
go0se
Card ran without issue overnight on the original tf536r1_main_top
Tested the other firmwares Using 37.350 ROM:
Guru on tf536r1_main_top_CLK6
Boots and runs on tf536r1_main_top_CLK7
Others below and above6/7 give a combination of Yellow/Green screen errors + pulsing Keyboard power light.
Guru with tf536r1_main_top_FULL_PHASE_6.jed
- Admin sponsor
Same herego0se wrote: 18 Jan 2020 11:33 Card ran without issue overnight on the original tf536r1_main_top
Just ran the hot air over mine in a A500+ Rev 8. No issues.. Fast and sweet.
Dont get it.
EDIT: even grabbed a BBQ lighter and fired it off over the cpu, ram, cpld... about 1 inch away.. no crash running frontier
