Check if your IP is banned
viewtopic.php?t=7286
Limited TF536 Run - Sort of Sales (All gone)
68030 + SDRAM + IDE
PaulJ_2.0
Re: Limited TF536 Run - Sort of Sales (All gone)
Post by PaulJ_2.0 »
I've removed/replaced/reflowed everything multiple times and only experience this error.
I've tried 2.2k and 1k resistor arrays, various diff caps on the CPLD and get no change.
Is there any other firmware I can try?
alenppc
Post by alenppc »
PaulJ_2.0 wrote: Fri Jan 17, 2020 6:56 pm I've removed/replaced/reflowed everything multiple times and only experience this error.
Yeah, I have done all these things and more. Nothing helps.
There is a "no-crash" test firmware with fast ram disabled, but none with fast ram that work reliably.
arkadiusz.makarenko
Post by arkadiusz.makarenko »
Are there any differences in ram chips then?
~ Stanislaw Lem
alenppc
Post by alenppc »
arkadiusz.makarenko wrote: Fri Jan 17, 2020 7:12 pm Are there any differences in ram chips then?
I am using the same ones I used on the 330, 360 and 1260
PaulJ_2.0
Post by PaulJ_2.0 »
Ram is: MT48LC16M16A2P-6A SDRAM, 256MBIT, 167MHZ, 54TSOP
8 Bit Dreams
Post by 8 Bit Dreams »
guys what power regulator have You used,
800mA or 1000mA?
Have 1000mA on all my TF330, TF534 & TF536 cards, maybe thats the difference ... :geek:
https://m.reichelt.de/ldo-regler-fest-3 ... stct=pos_1
PaulJ_2.0
Post by PaulJ_2.0 »
I'm using 800mA
I shall buy some 1000mA to test :)
alenppc
Post by alenppc »
800mA on everything
alenppc wrote: Fri Jan 17, 2020 8:46 pm 800mA on everything
I think i replaced your regulator too just to be sure. It all worked here.
go0se
Post by go0se »
Built this evening, unfortunately no issues to report as of yet but admittedly testing has been limited to AmigaTestKit memory test, Hard Drivin' and some Elite II (running for the last 90mins +).
Amiga 500 Rev6A with 0.5MB Chip Only. (No Trapdoor Expansion Fitted).
'Light' A500 PSU with 4.5A output on the 5V rail.
XC95288XL 10C
MC68030RC50C
AMS1117 - H734KME 3.3 Regulator
Kickstart 2.0 37.350 On AM27C400-120
MT48LC16M16A2P-6A RAM chips
Transcend 8GB 'Industrial' CF Card in Generic V.H2 CF adapter.
Classic Workbench 2.1 "Green Alien Edition" - Also GOTEK ADF boot of Elite and AmigaTestKit
I have several other permutations of Amiga to test so hopefully one or more will throw up the same issues.
Return to “TF536”
