Limited TF536 Run - Sort of Sales (All gone)
dalek
Re: Limited TF536 Run - Sort of Sales
One please :)
arkadiusz.makarenko
- Moderator Team
I would like one if still available.
I managed to build tf534 and tf328(edu port for A1200)
~ Stanislaw Lem
~ Stanislaw Lem
Justme14
Hi Sure ,
Interested in one,
As I already build all of the other TF boards that where available :D
Interested in one,
EzdineG
One please, have built every iteration of your (previous) boards successfully.
Thanks!
Thanks!
- Admin sponsor
All slots taken. :)
Subzero79
If rest one i want to build it :) :P
Subzero79
I have experience with 2 tf 530 one for my amiga 500+ and one for my friend chronis amiga 2000
Now i have and usb microscope
- Admin sponsor
Sometimes I get 11 with an order of 10. If i get a spare subzero will get it. Lets call it hes on standby.
adam
Re: Limited TF536 Run - Sort of Sales (All gone)
Promised photos attached.
Both 520s are ok at 20MHz.
530@33MHz works flawlessly, 530@50MHz crashes on latest Sysinfo after the 040 warning, still need to figure out why. Maybe it is the lack of FPU, maybe lack of RAM maybe CPU is not good enough or maybe my soldering (very unlikely;).
agranlund
Guess I'm late to the party - if you snooze you loose :)
If, by chance or magic, an extra one appears then I'm interested.
For my Atari 520ST
With the caveat that I expect to want to Atarify the firmware in a similar manner to what I did with the TF534. So I'd probably bug you with suggestions for changes (or just the source, that works too/better)
I have prevously built the TF534 and it's doing wonders for my Atari @50Mhz.
Really wouldn't mind having 64MB of TT-Ram though :)
For my Atari 520ST
Users browsing this forum: CCBot and 3 guests
