Nice work @exxos ,@Icky
FDC cookie
Re: FDC cookie
Very nice, I like the 1.44HD disk as used on the falcon. This will provide a good access point to exchange files with.
Re: FDC cookie
Doesn't TOS look for a specific bridged jumper on the STE in order to enable HD floppy support in TOS 2.06? I know it doesn't mean you can use HD floppies without the MOD, but maybe it requires a hardware jumper and not just the cookie setting in order to work?
Just my random thoughts.
Re: FDC cookie
@rubber_jonnie we have that jumper emulated in hardware, so it is set, only that register is never access for some reason..
Re: FDC cookie
@exxos Ah, ok I see. Could there be something that is specifically STE related which means it won't work?
Re: FDC cookie
So exxos got pi**ed off and did a binary hack in the OS...
Had a small side-effect
But for my first hack I think I did pretty well
Re: FDC cookie
At least its tracked down that its never going to work with the DIP switch settings on an STF as its also machine type specific i.e. STE
Re: FDC cookie
@Icky Yeah, the source is a mess! it seems to be literally checking for a STE machine.. I haven't yet quite followed exactly how it is doing that yet.. But I did not want to fake a STF machine as a STE anyway.. is more curiosity than anything... I will go snoop now actually...
Something to do with the video address register then
Also looks like after that code it checks for DMA sound as well.
#if (TOSVERSION < 0x300) | TP_50
move.b #90,(v_bas_l).w /* write low byte of video address */
tst.b (v_bas_m).w /* access the medium byte */
move.b (v_bas_l).w,d0 /* (which should reset the low byte on an STE!) */
cmp.b #90,d0 /* reset? */
bne.s nostedetect /* yes => STE detected */
clr.b (v_bas_l).w /* clear the low byte again */
tst.w (palette).w /* access the color palette */
tst.b (v_bas_l).w
nostedetect:
sne STEFlag /* <>0 => no STE hardware available */
#else
sf STEFlag
#endifSomething to do with the video address register then
