Slow STFM blitter oddness
Re: Slow STFM blitter oddness
Thanks! I don't get why my machine is slow and not others then :cry: :cry:
pixelpusher
Post by pixelpusher »
exxos wrote: Thu Jan 02, 2020 9:03 pm Thanks! I don't get why my machine is slow and not others then :cry: :cry:
If really you want to dig deeper into this, then please check if this slow-down happens with NVDI too and if it is reproducible in GEM_TEST too.
I could offer to check GB6' (runtime) use of OS calls with SysMon over the weekend (but only in an emulator, as I have no usb floopy drive for the PC yet and therefore can't transfer downloads to the real hardware). The comparision between the OS calls GEM_TEST and GB 6 use then should give a hint of which API functions are actually slowed down ...
Problem is I am somewhat limited to floppies and I doubt NVDI would even fit on one :(
pixelpusher
exxos wrote: Thu Jan 02, 2020 10:48 pm Problem is I am somewhat limited to floppies and I doubt NVDI would even fit on one :(
It does, if you don't add vector fonts (for DD probably remove also screen drivers not needed on an ST and also no printer drivers) or use NVDI 2.5x - that one definitely fits on a DD disc.
thorsten.otto
Post by thorsten.otto »
NVDI 2.51 should fit on a floppy
czietz
Post by czietz »
What's fairly obvious is that your STFm is slow when text is involved, which is when the Blitter copies data (the individual glyphs) from ROM to screen.
For the record, my other STFm with Blitter and TOS 2.06:
I'm not having much luck with NVDI :roll:
It might be lack of RAM as I think this is only a 512K machine... ?
Tried to find NVDI 2.5 and can't see it anywhere. I also swapped the GLUE,MMU,BLITTER for other chips and no change.
pixelpusher
exxos wrote: Fri Jan 03, 2020 2:21 pm Tried to find NVDI 2.5 and can't see it anywhere. I also swapped the GLUE,MMU,BLITTER for other chips and no change.
I have the original disc, but no USB floppy yet to transfer data to/from the PC ... - any recommendations which drive to buy and which to avoid? I checked a 1 MB STF with the UBE adapter that arrived today (thx!) + NVDI 2.5 and there's plenty of RAM free (512k RAM would be sufficient).
pixelpusher wrote: Fri Jan 03, 2020 6:34 pm any recommendations which drive to buy and which to avoid?
I'm still using good old internal floppy drives :) USB drives don't tend to do extended formats from what I understand, so they pretty useless for me.
pixelpusher
exxos wrote: Fri Jan 03, 2020 7:16 pm
Then you're probably not using a current MB : -) - for many years neither Intel nor AMD have floppy support on their MB anymore (and I haven found a floppy controller PCIe 1x-card via Google - only USB based solutions).
