Network Tools needed (Remote Amiga Login)
Re: Network Tools needed
OK i've been able to replicate this for both telnetd and ttyhandler
However my machine hangs for ages on boot when ttyhandler is in my servers file.
Ok to summarize in addition to your steps for ttyhandler I
1. Needed to add "wait" to the server file
telnet stream wait Sys:serv/ttyhandler
2. Add an assign for AmiTCP: or i got a requester asking for it when login then a crash.
Not sure what i should add to S:Remote-Startup
Sample output
Trying 192.168.0.79...
Connected to 192.168.0.79.
Escape character is '^]'.
Login: root^M
             Password:
                       TTY0
New Shell process 9
Welcome to AmigaOS 3.1.4
9> work:whichamiga/whichamiga
WhichAmiga 1.3.3 (2.5.99)
Written by Harry "Piru" Sintonen. Copyright  1995-1999 PitPlane Productions.
Evaluating system...
 Central Processing Unit: MC68060 62.8 MHz (rev 6)
    Floating Point Unit: 68060fpu
 Memory Management Unit: 68060mmu running
   Custom graphics chip: AGA Lisa 4203 (rev 0)
  Custom animation chip: AGA PAL Alice 8374, rev 3-4
   Other custom chip(s): Paula 8364 (rev 0), Gayle (rev 13)
        Graphics system: Amiga AGA  display bandwidth: 4x
         Hardware Clock: not available
 Max. Chipmem available: 2032 K
 Max. Fastmem available: 131072 K
       ROM chip version: 46.143 (Kickstart unknown)
      Workbench version: 45.194 (Workbench unknown)
       SetPatch version: 43.7
     Expansion board(s):
5080/1: Unknown Man.ID #5080 Unknown Prod.ID #1 (@$40000000 128M)
5080/130: Unknown Man.ID #5080 Unknown Prod.ID #130 (@$00E90000 64k)
 Your computer is an Amiga 1200.
  9>
dalek
Post by dalek »
Nice. S:remote-output can be whatever you want to run at login, like a unix .profile. e.g. you could put your build/run logic here instead of running it remotely, or just leave it empty.
Or you can do the build logic remotely. Personally I'd skip the native build over NFS/Samba if possible, and instead build on linux - then trigger the binary download and run it with an expect. Roadshow gives you wget, so as an example here's a quick expect script generated with autoexpect that retrieves a binary from a webserver and runs it:
#!/usr/bin/expect -f
set timeout -1
spawn $env(SHELL)
match_max 100000
expect "$ "
send -- "telnet 192.168.1.4\r"
expect "Login: "
send -- "root\r"
expect "Password: "
send -- "root\r"
expect "> "
send -- "wget -O RAM:mybin http://192.168.1.3/~dalek/WhichAmiga\r"
expect "> "
send -- "protect RAM:mybin +E\r"
expect "> "
send -- "RAM:mybin\r"
expect "> "
send -- "endcli\r"
expect eof
Then run it like:
linux$ expect script.exp
spawn /bin/bash
linux$ telnet 192.168.1.4
Trying 192.168.1.4...
Connected to 192.168.1.4.
Login: root^M
Password:
TTY0
New Shell process 6
6> wget -O RAM:mybin http://192.168.1.3/~dalek/WhichAmiga
--08:38:48--  http://192.168.1.3/~dalek/WhichAmiga
           => `RAM:mybin'
Connecting to 192.168.1.3:80... connected.
HTTP request sent, awaiting response... protect RAM:mybin +E
200 OK
Length: 20,472 (20K)
 0% [                                     ] 0             --.--K/s             100%[====================================>] 20,472        --.--K/s
08:38:48 (1.63 MB/s) - `RAM:mybin' saved [20472/20472]
6> RAM:mybin
6> endcli
 Your computer is an expanded Amiga 2000+.
6> Process 6 ending
Connection closed by foreign host.
yeah i may build on Linux but i need to be able to send command line params to my tool.
One curiosity is i cannot get lha to work over ttyhandler. it hangs.
dalek
Post by dalek »
parameters can be passed in to expect (and then on to the run command) or as part of your build generate a run script with the required args and wget that as well.
Weird about lha over ttyhandler - it works for me:
6> cd RAM:
6> lha x dh2:WhichAmiga
LhA Freeware Version 2.15 68000+
Extracting from archive 'dh2:WhichAmiga.lha':
 Extracting: (       0/    1233)  WhichAmiga.info                  1233            1233
 Extracting: (       0/    3482)  WhichAmiga/WhichAmiga.info                  3482                  3482
7 files extracted, all files OK.
Operation successful.
6> lha a tmp.lha WhichAmiga
Creating new archive 'tmp.lha':
   Freezing: (       0/   20472)  WhichAmiga                 20472     Frozen: ( 41.9%)   20472 =>  11874 : WhichAmiga
   Freezing: (       0/    3482)  WhichAmiga.info                  3482     Frozen: ( 44.9%)    3482 =>   1917 : WhichAmiga.info
5 files added, all files OK.
which TTY/client are you using?
dalek
Post by dalek »
putty on windows => ssh to debian linux => telnet to winuae
Are you using the same version of LhA (2.15)?
looks like i have lha 2.2
see the same hanging behaviour if i try and use a ctrl-c or ctrl-d
EDIT: e.g try and stop a ping command.
dalek
Re: Network Tools needed (Remote Amiga Login)
Post by dalek »
Looks like lha 2.2 is old - try http://aminet.net/package/util/arc/lha
Yeah I can't send ctrl+c etc either - looks like ttyhandler doesn't pass it even when sent in raw mode. That's a bummer.
I guess one day recompiling and debugging telnetd2.0 against roadshow is on the cards :?
Users browsing this forum: CCBot and 5 guests
