TF520 and Atari ST ...
TF520 - 68020 Board
frank.lukas
Re: TF520 and Atari ST ...
Post by frank.lukas »
The TF520 works principle but the computer starts not every time when I switch it on. I have to switch on 10 times before it boot up.
Try adding 1k pull up on reset.
frank.lukas
Thanks, seems to be better ...
Return to “TF520 (OBSOLETE)”
Users browsing this forum: CCBot and 3 guests
