:o)
Noob building a TF534
Lynxman
Re: Noob building a TF534
Post by Lynxman »
Well worth it. I had to install an A500 kickrom and set the noautovec variable to on but just about everything works now. I probably need to add some newer kickroms too. Some games complain about needing 1 MB chip ram but that's rare. I'll build a ram expansion for the old girl too to fix that. Can't have unoccupied expansion slots. :)
Lynxman
Post by Lynxman »
I might be able to score an old Amiga used for running commercials on the local cable TV network since the 90's. I have no idea what it is. He said he would try to find it. Could be anything from A2000 and up I guess. I'm pretty sure it's a big box machine.
8 Bit Dreams
Post by 8 Bit Dreams »
Expansion will not help (unless You have an A500+ machine)
You need to expand ChipRam to solve this..
Lynxman
Post by Lynxman »
I have an 8372A Agnus and can add 512 kB more and configure as chipram. I only have the stock 512kB chipram now.
8 Bit Dreams
Will be not enough for some games
Cannon Fodder for example needs more
Maximilian
Post by Maximilian »
If I remember correctly there was an issue with WHDLoad and Cannon Fodder where you would need 1088KB Chip and at least 512KB slow/fast men.
There was a patch for it that made it 1024KB chip and 512KB slow/fast.
I would just try the expansion/MB jumpers and otherwise get one of the 8375/8375 A500 adapters if you have an 6a rev board or lower, make sure it fits with you accelerator card first.
Lynxman
Post by Lynxman »
I ordered an DIY expansion board kit. Will report how it goes.
https://www.ebay.com/itm/Amiga-500-512k ... 2749.l2649
theq
Post by theq »
FYI: Some original (uncracked) floppy games will not work with TF534 and expanded internal memory. I had to remove the memory expansion to get it to work on an A500+.
Edit: Lemmings is one of those games
PaulJ_2.0
Post by PaulJ_2.0 »
theq wrote: 02 Feb 2020 06:46 FYI: Some original (uncracked) floppy games will not work with TF534 and expanded internal memory. I had to remove the memory expansion to get it to work on an A500+.
What kind of lunatic plays original games?
:D
theq
Post by theq »
PaulJ_2.0 wrote: 02 Feb 2020 10:57 What kind of lunatic plays original games?
:D
Completionists with OCD like me? :D
Return to “TF534 (OBSOLETE)”
Users browsing this forum: No registered users and 3 guests
