Noob building a TF534
supaduper
Re: Noob building a TF534
Post by supaduper »
How are you powering the TF530 ? with it off the A500 ?
By looking at your pic with the pins from the Ras pi you only have 5 for the JTAG and no power lead from it which is pin No 1 (3.3v) on the GPIO, so connect a lead from Pin 1 to the 3.3v on RasPi the 3,3v pin on the Jtag port then it will power the CPLD for programming
Lynxman
Post by Lynxman »
I first tried the command alone. I also tried with 5V connected to pwr1, but it made no difference since the software throws up an error before it even tries.
I'm installing your ISO on the SD card now. Hopefully it boots on my pi 2b. Winimage didn't work, BTW, since it's a vhd file but I'm using HDD raw copy tool instead which reads the image just fine.
Lynxman
Post by Lynxman »
Nope. Doesn't work. My rpi 2b doesn't boot or even show any activity. Back to a clean image I guess.
supaduper
Post by supaduper »
I use Winimage only to backup and write HDD raw wont work
Lynxman
Post by Lynxman »
Well I am stumped. If I try to open the "RaspberryPI 8GB with xc3sprog.vhd" image in winimage it asks which partition to connect to, of four available, and thinks my 8 GB SD card is a floppy disk.
supaduper
Post by supaduper »
You are doing something wrong many people have used the image with no problem
Run Winimage then select DISK in the drop down find your SD card
Then select DISK again and select `Restore Virtual harddisk`
In the window that opens just search for the IMAGE you are restoring then click OK, thats it
** important**
Your SD must have the same storage capacity as the image you are restoring or more !! to small and it wont work obviously
PaulJ_2.0
Post by PaulJ_2.0 »
I use Win32diskimager, it's foolproof with no options other than to read or write.
Download, write the image and install into the Pi.
Firmwares are there as ram.jed and bus.jed
Lynxman
Post by Lynxman »
supaduper wrote: 04 Dec 2019 11:02 You are doing something wrong many people have used the image with no problem
** important**
The disk is bigger. When I try "Restore a virtual hard disk image" it doesn't let me pick
Thanks. It worked when I opened Windosk with administrator privileges. The sdcard would not show up in the "restore from virtual hard disk image" menu without admin.
supaduper
Post by supaduper »
Lol yeah you need Admin Privs :)
Lynxman
Post by Lynxman »
It shows up on my old Xeon with Win 10 Pro now but the option to restore virtual hard disk is greyed out on my modern pc with i7 7700 and Windows 10 Home. I moved to the newer machine earlier to transfer the image because my old 1366 socket Xeon has unstable USB ports. I literally must have tried every coneivable thing in the software on that machine. What a weird set of problems.
Return to “TF534 (OBSOLETE)”
