You don't need to delay it, not unless you're using a booster to speed up ROM ( but that can be fixed in the booster anyway) , as the CPU will not pick up the data for 100+ns anyway.
Smonson's slow H4 build
Re: Smonson's slow H4 build
What about /OE though? Just tie it to ground?
Yes, I believe so. That part is from the schematic provided by the original author (Ted Rossin). By ROM_OE, do you mean LDS/UDS?exxos wrote: Fri Mar 26, 2021 12:00 pm If you are just using U4 for DTACK.. I really would not bother, just use a diode and tie to ROM_OE...
You can tie CE to GND.. OE is used to enable the ROM.. then put a diode to The same signal with a diode then you can pull DTACK low as well.
I used the GAL to do the address decoding, which controls /OE and the /AS line to run /CE on the ROM. (This matches the timing diagram as /CE should be before /OE.) This meant that the ROM was primed to output whenever an address appeared on the bus. It was then up to the GAL to decode the address or /ROM2 along with /RW to determine if it's a read operation so as to enable the output from the ROM (/ROE in my schematic). This same signal was used to enable /DTACK via the 74LS244.
Ah, got it. Like this, yeah? (ignoring the signal naming of "CE" which is now misleading)exxos wrote: Fri Mar 26, 2021 12:35 pm You can tie CE to GND.. OE is used to enable the ROM.. then put a diode to The same signal with a diode then you can pull DTACK low as well.
I could go down the custom route using a cheap CPLD, but using "F" high-speed logic seemed a lot more bullet-proof. I also can't stand soldering the EQFP packages on MAX Vsstephen_usher wrote: Fri Mar 26, 2021 12:40 pm
Yep!Smonson wrote: Fri Mar 26, 2021 12:51 pm Ah, got it. Like this, yeah? (ignoring the signal naming of "CE" which is now misleading)
But CE should be OE on the diode signal
Sweet, thanks! Let's just pretend that says OE there. It's just a net name!
For this particular application, I really would suggest using slower LS types... With them being lower power and slower they are a lot less "noisy".Smonson wrote: Fri Mar 26, 2021 12:53 pm but using "F" high-speed logic seemed a lot more bullet-proof.
Alright, I'll take your advice on that too. Thanks again!exxos wrote: Fri Mar 26, 2021 12:58 pm For this particular application, I really would suggest using slower LS types... With them being lower power and slower they are a lot less "noisy".
