Busy Bee in EmuTos
General Discussion, STOS.
Cosmic Puppet
Re: Busy Bee in EmuTos
Post by Cosmic Puppet »
Thanks @czietz ! Excellent. Works. Now I can try out the others. The coffee mug loading icon made me laugh. :lol:
I really appreciate this. :thanksblue:
BlankVector
Post by BlankVector »
Cyprian wrote: 28 Nov 2019 21:46 copy files emucurs1.def / emucurs1.rsc to C:\ and rename them to emucurs.def / emucurs.rsc
Note that DEF files are useless for EmuTOS itself. They are only used by resource editors to display object names. Just ensure that you have a file C:\EMUCURS.RSC (or A: if you booted from floppy) then everything will work nicely.
Subscribe to my Vretrocomputing channel on YouTube and Facebook. Latest video: Display a color pixel in assembly language on Atari ST.
Cyprian
Post by Cyprian »
BlankVector wrote: 29 Nov 2019 12:24
thanks for clarification,
would be cool to modify EmuTOS readme.txt because it contains following part:
To use a replacement set, move or rename the existing emuicon.rsc &
emuicon.def files in the root directory, then copy the files containing
the desired icons to the root, and rename them to emuicon.rsc/emuicon.def.
(2) a sample mouse cursor set in a resource (emucurs.rsc/emucurs.def). This
set is the same as the builtin ones, but you can use it as a basis to
create your own mouse cursors.
To use a replacement set, copy the files containing the desired mouse
cursors to the root, and rename them to emucurs.rsc/emucurs.def.
http://260ste.atari.org
Return to “SOFTWARE”
Users browsing this forum: CCBot, trendiction [bot] and 2 guests
