RJ's Attempt. Maybe he's going to finish this time!
Re: RJ's Attempt. Maybe he's going to finish this time!
If all is well, the IDE interface will be getting a try out.
PaulJ
Post by PaulJ »
@rubber_jonnie , I told @PhilC earlier that you were in training and was going to kick some serious butt building the H4! Don't let him try and pawn off his fupaw on you so he can expunge the fame that has come with his perpendicular IC installation technique.
Funnily enough I'm just on the way home from karate training 😁
PaulJ wrote: Fri Feb 14, 2020 9:11 pm @rubber_jonnie , I told @PhilC earlier that you were in training and was going to kick some serious butt building the H4! Don't let him try and pawn off his fupaw on you so he can expunge the fame that has come with his perpendicular IC installation technique.
But it genuinely fit better that way round.
PaulJ
Post by PaulJ »
PhilC wrote: Fri Feb 14, 2020 9:16 pm
I have to give ya that... when I first looked at it that looked right but after a little research... nope. So I had to purchase my own award!!
PaulJ
Post by PaulJ »
rubber_jonnie wrote: Fri Feb 14, 2020 9:14 pm Funnily enough I'm just on the way home from karate training 😁
All excited to kick some Butt I assume.. :excited:
PaulJ wrote: Fri Feb 14, 2020 9:44 pm
Definitely!
Hmm, yes, intersting orientation!
Well, I really wish I'd fitted the LS11 when I was doing all the other SMT stuff, because with everything around it it wa completely hideous to fit to the point where I may have shouted at it once or twice.
The pins buzz out to where they should though and there's no shorts.
Bad news is that I still just get a white screen during boot, and when scoping out things like /HALT, /AS etc, I see the same as on my Mega 4, which also boots to a white screen.
/HALT is permanently low, apart from reset when it jumps high brifly, so either the CPU is getting garbage data and halting, or something else is causing the line to stay low, some sort of HW issue.
Onwards and upwards as they say, diag cart time, plus some of the suggestions @exxos made re the Mega4. I wan't to get both of them running, and it's soaking up a lot of my time, but hey ho, isn't that the pointof a hobby?
