H4 FIXES & KNOWN ISSUES
Re: H4 FIXES & KNOWN ISSUES
Just checked R21 and R22 on the H5 and they are still set as 1K. Have changed the values on the H5 to 470R.
troed wrote: 11 Jun 2020 21:42 Maybe changing this in the BOM? I just soldered the 1Ks in according to that list - then saw this ;)
Yeah, I should probably do that :)
Post by JezC »
Might also be worth adding the PLCC 44 socket for the PROM at the same time (unless you've already done so...)?
