Choosing between three Sony MPF-920 drives
Re: Choosing between three Sony MPF-920 drives
The only thing the switch can do is set WP low so that TOS will "probably" re-read the FAT. The drive cannot spin up or read things on its own.
TOS sends the commands to the 1772 to spin up, TOS also sends the command to read track 0. All the drive can do is "try" to inform TOS that the disk might have changed so TOS will re-read the FAT.
IIRC this behaviour various across TOS versions, its possible like TOS1.00 doesn't work regardless of what is done. I never checked.
You should use the program I wrote to see the status of what TOS sees.
Pacman
Post by Pacman »
I've tried your Media check program but didn't quite understand how to use it (yes, I've read the docs on the above page). Do you insert/remove floppy disks and see what the message is or does it simply "analyse" the drive once to determine the type of disk detect mechanism used? Also I could never figure out how to quit (neither the most obvious Q, CTRL-Q, ALT Q or ESC worked). It flashes "disk may have changed!!!" here by the way. That's with the CTIN switch shorted.
So did my checking reveal anything new?
STe | MonSTer with dual IDE-CF memory card adapter | NEC Multisync 1990SXi | ST_ESSC | RSVE | Link '97 | Sony HD floppy drive/AJAX controller | Exxos HD floppy module | Battery-backed Ricoh realtime clock module | Discovery cartridge | C-Lab Unitor-2 | C-Lab Export | C-Lab Combiner | C-Lab Steady Eye | C-Lab Human Touch | Unicorn USB
💧Are you a good person? 💧Living Waters
There likely isn't a quit, it was wrote in a hurry and only for a quick indication, it wasnt intended as a full app by any means.
TOS will say "might have changed" if it detects WP going low. If it does not, the message will read "not changed" or something like that, I don't remember all the messages exactly.
The program simply polls what TOS is reading from the drive, thats all.
Pacman
Post by Pacman »
The preliminary conclusion is then perhaps that with a Mega STe at least I will still need to have CTIN shorted on a Sony MPF-920 drive while with a normal ST (such as my STe) and the version 6 Exxos HD module board I might not (as the HD module takes care of everything). I'm soon going to attend to the STe, so we'll see.
Pacman wrote: 23 Oct 2017 23:51 The preliminary conclusion is then perhaps that with a Mega STe at least I will still need to have CTIN shorted on a Sony MPF-920 drive while with a normal ST (such as my STe) and the version 6 Exxos HD module board I might not (as the HD module takes care of everything). I'm soon going to attend to the STe, so we'll see.
I've got to hook up a machine later anyway, so I will try Sony drive and solder over the switch to see if it does anything. It could be the switch does the same job as the V6 module, in regards to media detect, though when I was originally designing the kit and experimenting with floppy drives, a lot of the drives did not have this switch anyway, so I never really investigated it on the drive itself.
So with TOS 206 & TOS 104 with the floppy write protected, without any mods to the drive, initially the programme says disk has definitely not changed, the when the floppy drive motor turns off, it says disk may have changed. So would see media detect works perfectly well here.
However with the floppy write enabled, with TOS 104 & 206, it says the disc has definitely not been changed.
I soldered over the second switch on the back of the drive, and still says disk has definitely not been changed.. So soldering over the switch did not do anything.
When I eject the floppy it says the disc may have changed.. This is with the switch Soldered over.
Without the switch soldered over the message stays on disc has definitely not changed..
So it appears the switch does do something when soldered over, but only when the floppy itself is ejected. Obviously write protect also has the same effect.
In any case, it would seem beneficial to solder over the switch, then it least TOS will recognise the disc has been ejected and likely being changed, so it will reread the FAT.
On my floppy module, the media detect should say the disc has changed without ejecting the floppy... So every time the disc is accessed, changed or not, it should reread the FAT.
