Thanks @ari.tao Good to know these things. 14 partitions is definitely more than I need anyway.
I also have everything backed up on the PC. I keep testing new things I find. Some things work on EmuTos with NVDI 5 (Monochrome Missile Command etc)
Found a program yesterday called AntiBomb which displays the meaning of the bombs instead of the Bombs of Doom. :lol:
Trying to use both SD slots on the UltraSatan.
Cosmic Puppet
Re: Trying to use both SD slots on the UltraSatan.
Users browsing this forum: CCBot and 40 guests
