Wizztonics TOS206 upgrade issue - SOLVED
Re: Anyone have it? know it?
ooohhh.. That track is cut when the blitter patch is installed... If you remove the patch then you have to repair that track on the bottom of the CPU.. It actually says the track cut on my mega page as well.
Users browsing this forum: CCBot, Google [Bot] and 59 guests
