32.084988MHz oscillator
PaulJ
Re: 32.084988MHz oscillator
Didn't know that. How do you access that capability? Search etc. Away thanks for the info czietz. :D
czietz
One example: https://www.digikey.com/product-detail/ ... D/10483164
Be sure to choose correct package and supply voltage (i.e. 5V for Atari), provide desired frequency in the note field when ordering and they will custom-make your oscillator.
PaulJ
@czietz, thats a nice feature! Every time I look for oscillators its a pain in the arse. That makes it easy. I'll have to give it a try. :thanksblue:
I never knew that either! though I seriously hate digikey :roll: I have had nothing but troubles with them from start to end and not use them for years now.
PaulJ
Ya, I don't use digikey normally, Mousers my vendor of choice. But if this worked out it would be an asset.exxos wrote: 02 Jan 2020 17:51 I never knew that either! though I seriously hate digikey :roll: I have had nothing but troubles with them from start to end and not use them for years now.
Users browsing this forum: CCBot and 13 guests
