Check if your IP is banned
viewtopic.php?t=7286
Memory test on TOS 2.06 (STE)
dazcoull
Re: Memory test on TOS 2.06 (STE)
Post by dazcoull »
Cover off PSU might not be a bad idea, the amount of screws on that piece is crazy, perhaps Atari wanted the steel casing to give the whole thing a feeling of solidity!
As for RAM, the new set from exxos is I think 70ns so if there is ever a new booster for STE made available, I might be tempted.
dazcoull wrote: Sun Nov 03, 2019 10:45 am As for RAM, the new set from exxos is I think 70ns so if there is ever a new booster for STE made available, I might be tempted.
ST RAM speed can't be increased with any boosters on the STE.
dazcoull
Post by dazcoull »
Indeed, but some sort of CPU booster may still be on the cards once I've got it running nicely - at least RAM module speed compatibility won't be an issue with your newly manufactured RAM kit fitted :-)
