Is there any way to add RAM without physically installing it?
General Discussion, STOS.
Cosmic Puppet
Re: Is there any way to add RAM without physically installing it?
Post by Cosmic Puppet »
I installed these two on seperate SD cards. All other files identical other than these installers.
Annotation 2019-11-03 153756.jpg (11.97 KiB) Viewed 2645 times
And found that the high Notator RAM versions are missing the BT Fonts folder.
Annotation 2019-11-03 153401.jpg (158.11 KiB) Viewed 2645 times
Looks like you have your answer then :)
Cosmic Puppet
Yes. If I delete the BT Fonts folder it leaves over 90,000 bytes more to Notator!
Both installations still have this:
NVDI Installation.jpg (39.48 KiB) Viewed 2628 times
But the setup without BT Fonts will be a file path to nowhere.
Return to “SOFTWARE”
