Is there any way to add RAM without physically installing it?
General Discussion, STOS.
Cosmic Puppet
Re: Is there any way to add RAM without physically installing it?
Post by Cosmic Puppet »
Cosmic Puppet wrote: Wed Oct 30, 2019 3:43 pm
DoG wrote: Wed Oct 30, 2019 3:27 pm Control Panel replacement. You don't need it.
Thanks for that. Helps a lot! :)
I'll put xcontrol back as Notator doesn't mind it and I can use it to check the time without leaving the ST.
Cosmic Puppet
exxos wrote: Tue Oct 29, 2019 9:14 am EMUTOS should be run with NVDI. Though that will eat up more RAM.
While troubleshooting Snap it crashing Notator and trying different setups, I accidentally discovered the following:
If I run my set up using your NVDI HD Installer, I get 325559 bytes of RAM available to Notator and 2686 free in SysInfo.
Installed NVDI.jpg (84.92 KiB) Viewed 4800 times
If I run my set up using your NVDI Installed, I get 364483 bytes of RAM available to Notator and 2680 free in SysInfo.
Pre-installed NVDI.jpg (84.77 KiB) Viewed 4800 times
It really surprised me that there's very little difference in free system RAM, yet something is making more RAM available to Notator.
You would have to check every file and size in both setups. Maybe there's a missing font file in one or something. It was never checked.
Cosmic Puppet
exxos wrote: Sat Nov 02, 2019 9:36 am You would have to check every file and size in both setups. Maybe there's a missing font file in one or something. It was never checked.
I tested a few this morning:
NVDI Download Choices.jpg (66.99 KiB) Viewed 4786 times
miguel
Post by miguel »
You can use "kill score" to free up some of the RAM used by Notator and of course if you are using SL (Soft Link) you can partition RAM for running other stuff.
Cosmic Puppet
miguel wrote: Sat Nov 02, 2019 10:02 pm You can use "kill score" to free up some of the RAM used by Notator and of course if you are using SL (Soft Link) you can partition RAM for running other stuff.
Thanks. Good to know. It turned out that my main issue was being unaware of NVDI which has sped things up. I mistakenly blamed RAM for this.
Cosmic Puppet wrote: Sat Nov 02, 2019 8:52 pm I tested a few this morning:
I think the original installers was broken and was missing a load of files.. I put them back to make the install complete. As I said, you would need to do a folder comparison and compare every file to see where the RAM "leak" is . You may be able to delete more files to free up more RAM. I don;t know what NVDI loads as default, but IIRC there's printer drivers and fonts installed which you might be able to delete.
Cosmic Puppet
exxos wrote: Sun Nov 03, 2019 12:54 am
I'll test the two different resulting ones, and then find out why the two with the same results are so different in size. One of them is nearly 10 MB!
Cosmic Puppet
It's the HFE folder containing NVDE_D1.hfe and NVDE_D2.hfe making one version massive on the disk. I have no idea what these are for but it works without. I'll have to campare things on the Atari at some point to figure out the RAM "drain".
You need to know the files installed on your C: drive on the ST.. mostly whats in the NVDI folder and others.
Return to “SOFTWARE”
