RAM - IS41C16100C
- 8 Bit Dreams
- Moderator Team
Re: RAM - IS41C16100C
Noticed that power & GND header for external programming are missing, wanted to add them, and noticed that brd file isn't routed...what a mess
- arkadiusz.makarenko
- Moderator Team
I have noticed this. I think it is even recorded as issue on bug tracker.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
You know someone already ported the TF328 card for the A1200 with RTC and SPI?
EDIT: Actually there are at LEAST 2 ports to the 1200 of the TF328. Both are open source.
- 8 Bit Dreams
- Moderator Team
about 8MB expansions - don't know will there be much interest, just wanted to build one for my personal use, all i was able to find - was Edu's board..
As about a1200 connectors - im fully agree with Alen, collective purchase is the right choice, im in if this will be done, can take 200 - 300 pieces
- Admin sponsor
Kipper2k released the K1208 open source. The eagle files etc are linked somewhere on eab.8 Bit Dreams wrote: Tue Nov 05, 2019 4:08 pm about 8MB expansions - don't know will there be much interest, just wanted to build one for my personal use, all i was able to find - was Edu's board..
EDIT: www.kipper2k.com/tfpics/tf1200.zip
What is the unit cost on these? I'm considering doing a similar thing with these connectors as i did with the A3000 ones. Only downside is i'd need to charge VAT on each unit.As about a1200 connectors - im fully agree with Alen, collective purchase is the right choice, im in if this will be done, can take 200 - 300 pieces
- Moderator Team
Great. I did look for those, but couldn't find it. I assumed that only firmware was released.terriblefire wrote: Tue Nov 05, 2019 4:33 pm
Ps
Do you know if any TF330 ports to A1200 by any chance?
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Edu Arana has a TF330 port but he's had issues with it for some reason. I'll probably do the port myself if he doesnt get it working.arkadiusz.makarenko wrote: Tue Nov 05, 2019 5:21 pm Do you know if any TF330 ports to A1200 by any chance?
I can take ~200 if you're doing a bulk purchase from China. Sounds like there's enough interest here to make this happen.alenppc wrote: Tue Nov 05, 2019 4:44 pm According to the last quote, it was 1.58 USD a piece per 1000 pieces min. If we pool the resources I can even do the purchase and distribute the connectors accordingly since my import fees will likely be the lowest (15%).
Ok, I sent them an email... if all goes well I can order them and then we can split them. I can ship them with low value via UPS so that nobody gets additional charges.go0se wrote: Tue Nov 05, 2019 5:55 pmI can take ~200 if you're doing a bulk purchase from China. Sounds like there's enough interest here to make this happen.alenppc wrote: Tue Nov 05, 2019 4:44 pm According to the last quote, it was 1.58 USD a piece per 1000 pieces min. If we pool the resources I can even do the purchase and distribute the connectors accordingly since my import fees will likely be the lowest (15%).
For anyone interested in these just be aware that the Kipper2k board uses a straddle mount PCI type connector rather than the 150 position through hole connector on the Edu Arana version.terriblefire wrote: Tue Nov 05, 2019 4:33 pm
tf1200.zip
