I want to use this part onlyIcky wrote: Mon Jul 22, 2019 9:27 am Hi. I am not quite sure what you are trying to do based on your description.
In any case (excuse the pun) we are still working on the 3D files as although the prints look good from a far there are still issues with every section. A lot of effort and investment for the initial scans and time on modifying the issues has been made with these files and currently we are just trying to get the ST case completed.
of an Atari ST case as a standoff for this Midi PCB
to add to my 130XE , by cutting the leftside of it's topcase where there are no ports.
Basically I'm adding MIDI ports to my 130XE in the same spot as an Atari ST and since I only need that part I wanted to ask if you could provide me
the 3D files to print only this lefthandside top part of the bottom case since I only need the MIDI ports part.
I don't need the middle or righthand part of the bottom case.
Since your work which might I add is awesome is a close as the real deal it would suffice for my needs.
This would be a cleaner option than salvaging a complete Atari ST bottom case just to cutout a part from it.
The 3D print doesn't need to be perfect for my purposes.
