STFM case remake
Re: STFM case remake
Good work. And at least the modifications you need to do are simple to implement.
I've hopefully got the correct grey coloured filament arriving today as well.
Yeah working on sections at a time helps to break the problems down. Am still battling with the front part of the bottom case where the front grill is and pillars. Most of the work is getting done on my daily commute as this gives me a quiet hour each way and is a little different from reading a book or watching a boxset.PhilC wrote: Thu Jun 06, 2019 8:58 am Good work. And at least the modifications you need to do are simple to implement.
So the pillars are in the right place
. One bolted in floppy drive and motherboard, of course I am missing the shielding underneath.
Looking very good.
Bit darker than the falcon case colour.. kinda like it.. maybe we should call the remake "Dark bird" with that colour
"Project Dark Bird"..
How about " Project Dark Raptor"?exxos wrote: Thu Jun 06, 2019 1:29 pm Bit darker than the falcon case colour.. kinda like it.. maybe we should call the remake "Dark bird" with that colour"Project Dark Bird"..
I quite like Kestrel.
"Dark Pigeon"rubber_jonnie wrote: Thu Jun 06, 2019 2:03 pmHow about " Project Dark Raptor"?exxos wrote: Thu Jun 06, 2019 1:29 pm Bit darker than the falcon case colour.. kinda like it.. maybe we should call the remake "Dark bird" with that colour"Project Dark Bird"..
Am surprised no one has done the Dark Phoenix
Well that's just silly, everybody knows that the Phoenix isn't a real bird!!
I would suggest Dark Sparrow, but it's kind of already been done: http://www.old-computers.com/museum/com ... st=1&c=635
Dark Ostrich has a kinda ring to it. And if it all goes wrong you can be like the ostrich and bury your head in the sand
